Multiple electrical issues at once
IF SOMEONE HAS THE 2008 MODEL YEAR COMM NETWORK WIRING CAN YOU POST IT...I don’t want to give out bad wiring info !!...and BTW if you decide this may be a little over your head as far as diagnosing you MAY find 1 in a hundred dealerships that know how to diagnose this if you decide on having the dealer work on it !!
So first off, try a basic scanner on the OBDII port, and see if it will talk to the BCM. All the other modules talk to the BCM, so will tell you if the problem may be lines to the BCM itself, or if you can talk to the BCM, but say not to the ECM, then you know that the problem is the wiring down line of the BCM instead.
If basic scanner can talk to BCM, then could be a locked tune in the car, and this locks out the Tech II from being able to communicate with the BCM in the first place.
If tune is not locked, then disconnect the battery, then clean the OBDii pins, as well as pulling the BCM connectors to clean those connection as well.
And quick note, but if you can start the car, then BCM is communicating with the ECM and rest of the modules like the RCDLR, the Starter switch, brake or clutch switch, and ECM in the first place. Hence some cars that nothing has been plugged into the OBDII in a while, have has to put a towel down and go to town with spray electrical cleaner to clean the OBDII port pins.
The second one since you are running tech2win, make sure that you got all the windows to connect the MDI/Nano device to tech2win.
Hence when you started the cracked Tech2 win, should have got these screens.
Selector north America,
Attachment 48339756
Select Mdi 1 for nano,
Attachment 48339225
Select the device on the usb port,
Attachment 48339757
Then should end up at this screen,
Attachment 48335558
If you clicked on the Tech2win short cut, and went directly to the last screen without getting the other pop up screens and selecting the correct information, then you have problems with the Tech2 win software load and the MDI device was never connected to Tech2win in the first place. If such is the case, send me a email with your phone number and name, and I will call you to talk you through loading the software correctly.
If you are using TDS tech2win, them make sure you have the correct drivers and selecting the correct device, so it loading to tech2win to start with as well.
________________________________________ ______
As for bus's on the car, you have the main gm high speed land bus that is the tan wires on the main connectors, and will be the direct shot of the OBDII port to the BCM.
Then you have the serial 2 bus, that is on SP205 and SP206, and which other modules not on the main high speed bus, communicate with the BCM instead.
Note pin 2 from above on the OBDII port left middle of the above diagram, and the pin 2 noted from the above on the port pin position.
The SP206 splice block is a straight 11 wire connector, is located next to the Bose amp location.
In this photo, look at the upper middle of the bose amp where it has the two screws in the middle of it, and look to the left on the screw line to see the white top connector that is clipped to the plastic left of the bose amp (top left in the photo) that is the splice block.
Number 1
The SP205 is Number 5 in the below diagram, and again, just a straight single line connector. To get to it, you will need to pull the IPC bezel or you can pull the bottom bezel of the dash, but it the hard way, since it really up there in the dash bowels.
Also, may need to check the grounds on the module, if you can communicate with the BCM, but on not something down line of the BCM if the serial 2 wires/splice blocks are fine.
Your good on the serial 2 port (pin #2 on the OBDII port maybe*), but have problem on the main high speed bus pins/wires 6 and 14 isntead (tan wires).
*note that you have the jump wire between 205 and 206 on the spice blocks, and OBDII #2 lands on 205, has the wire jump to 206, and the BCM is on 206. So if you can communicate with say the HVAC controller, then has continuity to at least the 206 splice block from 205, and maybe only a problem with the L-gr wire to the BCM off SP206, or maybe even something most stupid, like a bad ground connection for the BCM at the ground point 5 instead.
Note, someone at GM should have been kicked right in the nuts for all the splice blocks that were using in the car wiring. Yes, it makes it easy to assembly the car, but the corrode over time, and makes troubling shooting continuity on the wires from end point to end point a PITA.
Start with cleaning the pins on the ODBII port, and then disconnect the battery to pull the BCM connectors (including the center one held on by the bolt) to clean both the connector pins and BCM pins with spray electrical cleaner as well. Also, pull the 30 amp fuse on the BCM (big blue one center), since it the can bus breaker, to make sure it not blow, or its U slot connector in the BCM having problems.
AND ... this thread is just amazing!
( ... still have not had it to 175 mph tho ... )
