2007 Base need a 'catch can' ?
Old Jan 7, 2021 | 07:09 PM
killain's Avatar
killain
Oldtimer
Default 2007 Base need a 'catch can' ?
I was just wondering about a Catch Can on my LS2, is a catch can needed on a base LS2, not really a wild driver.
Old Jan 7, 2021 | 07:58 PM
hubes's Avatar
hubes
Needed, no. Will you benefit from one, yes. A standard catch can doesn't do much at WOT anyway, it only works when there is a vacuum in the intake manifold
Old Jan 7, 2021 | 09:45 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Originally Posted by hubes
Needed, no.
Yup ... and there is vacuum in the intake manifold about 98% of the total time the engine is ever in operation.
Old Jan 8, 2021 | 12:49 AM
D-Dub2013's Avatar
D-Dub2013
I have been looking into this a lot for an 800hp blown ls3. Assuming your LS2 is stock there is absolutely no need for one. Money best spent else where. Add a supercharger...then yes get one. A stock LS2 or 3 C6 really dosen't "need" anything. In stock form these cars are set up well.
Old Jan 8, 2021 | 01:42 AM
Dano523's Avatar
Dano523
Yes on what you stated, since clean side of the PCV is where the oil is being drawn into the intake manifold on WOT, from the port in front of the TB.
No, that when you come off WOT with high revs, the dirty side of the PVC system will be pulling back in a lot of oil on the vacuum surge.
So if not rev ranging, no need for catch can, but if you are rev ranging a great deal, then both clean and dirty sides of the PCV system need to be caught if you are trying to keep the excess PCV system oil out of the intake manifold.
Old Jan 8, 2021 | 05:15 AM
Turbo6TA's Avatar
Turbo6TA
I still think a bone stock LS engine even could benefit from a catch can ... When my LS3 was bone stock, I removed the throttle body just to find that there was lots of oil laying in the bottom of the intake manifold (I wish I had taken a photo of it).
If a good / well designed catch can can keep even 50% of all this oil out of the intake, it would be worth it to me to install one.
Old Jan 8, 2021 | 07:27 AM
killain's Avatar
killain
Oldtimer
Thank you, I don't track or road cross the car in any racing or high revving incenses, once in awhile some WOT just to get the blood pressure up, and I'm a little confused by the capacity of a catch can. I see all different capacities and what is a realist capacity for a Catch car, if there was a need for one on a stock LS2. I like that idea of supercharging the stock engine, but again I have to realize what is the intended use. When you own a Corvette, you always want to be on the leading edge of advances or useful modification the are both money well spent and well thought out.
Thank you !
Old Jan 8, 2021 | 10:17 AM
Orion2011's Avatar
Orion2011
Not "needed". I put one on my 07 anyway.
Old Jan 8, 2021 | 01:39 PM
farmington's Avatar
farmington
Put one on my stock LS3 a few months ago. When I took the TB off to access the hose I needed to remove, there was a puddle of oil in mine too.
Old Jan 8, 2021 | 05:20 PM
killain's Avatar
killain
Oldtimer
What capacity Can did you install ? Brand . . .
Old Jan 8, 2021 | 06:41 PM
wjnjr's Avatar
wjnjr
A catch can is simply a liquid/gas separator with some built in capacity to store liquids removed from blowby vapors. It's purpose, other than to look cool at car shows, is to keep a nasty mix of oil & and a little water out of your intake manifold. A good one, installed correctly, will do just that.
Whether or not it is "necessary" is up to you.
Old Jan 8, 2021 | 08:05 PM
D-Dub2013's Avatar
D-Dub2013
Are there any reported engine failures related to not having one? Has anyone experienced any problems without one (other just visual residue) that can be blamed on not having one?
Old Jan 8, 2021 | 08:24 PM
hubes's Avatar
hubes
You might get a bit more carbon buildup
Old Jan 8, 2021 | 09:19 PM
Iceaxe's Avatar
Iceaxe
Mine holds 8 oz which is more than enough capacity if you empty it at every oil change. YMMV
Old Jan 8, 2021 | 10:43 PM
Turbo6TA's Avatar
Turbo6TA
Mine might hold about 6 oz. total, but I only drain about 1 oz. of oil out of it every 2,000 miles.
That's 1 oz. of dirty contaminated oil that is not going into my supercharger every 2,000 miles (and gumming everything up).
Does a great job of removing most of the oil from the crankcase gasses.
Old Jan 9, 2021 | 10:46 AM
jonjoy's Avatar
jonjoy
if you really got to have one I have one I never installed, cheap.
Old Jan 10, 2021 | 10:56 AM
killain's Avatar
killain
Oldtimer
How much ?
To 2007 Base need a 'catch can' ?
Old Jan 11, 2021 | 07:10 AM
BadAV's Avatar
BadAV
Won't hurt anything unless you don't empty it when full or it freezes, but not necessary. I put 75k miles on a cammed/pullied down MP112/stalled 5.3 in my 2002 Avalanche without a catch can and had no issues. 95k total miles on the truck when I traded to an F-150 in 2015.
Old Jan 11, 2021 | 09:55 AM
jonjoy's Avatar
jonjoy
96,000 on an 06 LS2 500 RWHP two or three drops in the manifold. Then again I don't drive around in Second at 6000 rpm and then pull my foot out of it because it sounds cool
Old Jan 11, 2021 | 04:34 PM
s7n7a7k7e's Avatar
s7n7a7k7e
Had one on my 06 GTO for peace of mind.
