But if the other car battery is connected to the terminal wires, there is no need for current to flow through the bad battery. You use the jumper cables to connect the jumper battery to the power system, not the dead battery. I have jump started a skidder which had no battery of its own attached, the only source of power before the skidder’s alternator started providing it was the jumper battery.
That’s why one of the tests for an alternator failing is to jump start the car with the dead battery and see if it keeps running once the cables are removed. You are disconnecting the external power source, and if the charging system isn’t working, the car dies.
Under normal circumstances, the car should crank with jumper cables and a jumper battery in another vehicle. Continuing to run after the cables are removed is an entirely different story, though.
I have seen a battery with a shorted cell that had good surface voltage but would not allow amperage flow, even with jumper cables hooked up and the donor car running. You really should verify that the battery is good with a load test. You are currently guessing it is good because it is only 5 months old.
I gotcha. I’m just trying to narrow down possibilities because I have super limited time to work on it right now unfortunately. I’ll have it load tested and see what happens.
Being that the battery was having issues maintaining a full charge not too long ago, I’m of the opinion that the battery has a shorted cell. You can’t jump start such a battery. Disconnect the battery from the terminal and then hook up booster cables to the unattached battery leads. If dash lights up....you’ve found your problem.
i replaced the battery that was having issues maintaining a full charge a few months back. This one is brand new.
Talked to the OP today and in the end if was a bad ECU which needed replacing. Just thought i'd close the loop.
Thanks for posting this, my fault I never posted the solution! Sure enough, the ECU was fried. Battery and charge system were all good, but the ECU wasn’t operating properly. Took it to Chevy to have them change it out, brought it to my tuner to have it retuned, and haven’t had a problem since. Unfortunately I am about to list the car for sale which I am super bummed about, but I have my eyes on a C7 Z in the near future😎
