Lifter swap - which ones to get?
Old Jan 28, 2021 | 08:17 PM
bwill03z's Avatar
bwill03z
I posted a thread the other day with a video but for those that haven’t seen it here it is for reference on why I’m looking at lifters. Both sides of motor, around cylinders 1/3 and 2/4.
This tick used to be even louder but I put some detergent in the oil and ran it a bit before an oil change and it quietened some. Around the 1:10 mark u can hear it good
Old Jan 29, 2021 | 11:10 PM
grpweld's Avatar
grpweld
https://youtu.be/xL0RQouo4jo
That sounds way worse than mine did & mine needed a cam and lifters, take a good look at the cam lobes while you are in there
Old Jan 29, 2021 | 11:22 PM
bwill03z's Avatar
bwill03z
Hopefully the cam isn’t wiped, but thanks I will
Old Jan 30, 2021 | 05:00 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
You do realize that the heads have to come off to get to the lifters and trays.
Old Jan 30, 2021 | 06:51 AM
bwill03z's Avatar
bwill03z
yes.....
Old Jan 30, 2021 | 08:12 AM
bwill03z's Avatar
bwill03z
How Good of a look can you get at the cam lobes by removing the lift trays and not actually pulling the cam? I shop is doing this work and if they have to pull the cam that’s gonna be a lot more in labor charges but I would assume you could probably get a good look at the cam lobes by removing the lifter trays?
Old Jan 30, 2021 | 09:09 AM
helga203's Avatar
helga203
They will pull the trays and lifters then you will be able to see the lopes. I'm sure there going to inspect them and it doesn't hurt to ask what all they are going to do.
Old Jan 30, 2021 | 12:59 PM
2008 Corvette
Default Lifters
. Lopes ? Lobes.
Old Jan 30, 2021 | 01:45 PM
bwill03z's Avatar
bwill03z
. Lopes ? Lobes.
No it’s lopes and that’s what gives it that lopey idle 😂
Old Jan 30, 2021 | 01:47 PM
helga203's Avatar
helga203
Old Jan 31, 2021 | 02:28 PM
bwill03z's Avatar
bwill03z
Btw I found the GM ls7 lifters available at a decent price, I just hope they are the legit GM ls7 lifters. It says they are part number 12499225 which is supposed to be the good ones. They are at Michigan Motorsports, has anyone ever dealt with them?? At Summit they are like $315
Old Jan 31, 2021 | 02:57 PM
jamieo's Avatar
jamieo
Bought a few parts from them.Never any issues and great service from them.Good luck with your issue
Old Jan 31, 2021 | 03:15 PM
  #33
bwill03z's Avatar
bwill03z
Great, thank you!
Old Jan 31, 2021 | 04:50 PM
  #34
irok's Avatar
irok
that lifter is the same one p/n 12499225 used in the LS2 & LS7.they came numbered like that for the 16 lifters. lots of lifters are on the net that are fakes.look at the GM race lifters p/n 88958689 for about the same price.$369. at juicedmotorsports.com
Old Jan 31, 2021 | 04:56 PM
  #35
bwill03z's Avatar
bwill03z
Yeah I know that’s what I’m afraid of, I don’t want the cheaper “ls7 style” ones or the Delphi ones... that’s why I previously asked about the reputation of that company.
I did look into the ones you mentioned and believe those are the “caddy race lifters” and I know they are supposed to be good but I also read there were mixed reviews on them because of failures. They are close to $400 and if I can get legit GM ls7 lifters for $260 i’ll prob go that route. I’m going to call Michigan Motorsports tomorrow and talk to them.
Old Jan 31, 2021 | 05:10 PM
  #36
irok's Avatar
irok
they are the best lifter GM makes and are $50. more than the older style lifter.fake news with that lifter failing with all the copie's on line
Old Jan 31, 2021 | 05:15 PM
  #37
bwill03z's Avatar
bwill03z
Are they the same exact dimensions as the LS7 lifters and also require the same preload? If so I may just go with those.
To Lifter swap - which ones to get?
Old Jan 31, 2021 | 06:10 PM
  #38
irok's Avatar
irok
I have them in my LS2 and use stock 7.400 push rods.Preload is flexible on these engines
Old Jan 31, 2021 | 06:26 PM
  #39
2008 Corvette
88958689 LS7 lifters are the real deal. You get what you pay for.
Old Jan 31, 2021 | 06:51 PM
  #40
bwill03z's Avatar
bwill03z
You guys positive that the 88958689 lifters are a direct replacement for the stock ls3 lifters and will work fine with the stock cam and pushrods? I don’t mind to pay a bit more as long as I know they are good
