C6 Harmonic Balancer issues
Old Jan 30, 2021 | 12:26 AM
Tahoe's Avatar
Tahoe
Default C6 Harmonic Balancer issues
I've seen the results of high age / mileage harmonic balancer failure on youtube. My 2011 G.S. / 6M occasionally sees 7K rpm. At what age/mileage should I consider A Summit pulley & crankshaft pin kit ? Has anyone had a balancer go out/ wobble or vibrate on their daily driver?
thank you
Old Jan 30, 2021 | 12:59 AM
HK770's Avatar
HK770
Replaced Damper at 16000 mi on om 11 G.S. was wobbling and noisy. Replaced it with ATI and Rpm Bolt and pinned it. As far as pinning goes there are two kits. I pinned horizontally as to perpendicular to crankshaft. Now if I need to remove damper I will have to re-drill crank.
Will never be able to align crank and damper back up to use same hole.
If you drill perpendicular you use the key way and slide damper onto crank like old school. then if it needs to be removed slide it off and back on using keyway.
(SHOW/TELL) .............. Might not be for your engine !!!!!!!!!!!!
https://www.summitracing.com/parts/a...RoCrH4QAvD_BwE
Old Jan 30, 2021 | 05:10 PM
Tahoe's Avatar
Tahoe
Thank you.....wondering if future problem can be prevented with ATI Crankshaft Pin Drill Fixture Kit........no power adders on my NA LS3?
Old Jan 30, 2021 | 06:53 PM
HK770's Avatar
HK770
That's why I went aftermarket damper, I just choose ATI. The OEM bolt is torque to yield (one time bolt) And a special torque sequence.
I choose ARP crank /damper bolt and used their torque values
The problem seems to be the damper itself (poor design/materials) GM did not correct and we have trouble with them. Engines for many,,,,many years had a keyway in crank and damper. Even if the crank bolt loosened up the damper could still not spin on crank and chew it up.
With LS engines there is no keyway or key, aftermarket dampers still have a keyway for the most part
Most people think if your going for more power SC//TC you need to pin crank. I was there with the damper and it seemed the thing to do! Never like to repeat my self, when it can be done in the first place and be done with it.
Luck
Old Jan 30, 2021 | 09:28 PM
Tahoe's Avatar
Tahoe
sounds like new damper + pin kit (AT-918993) + bolt will do it! Whose damper do you recommend?
thank you
Old Jan 30, 2021 | 09:52 PM
HK770's Avatar
HK770
I am not the one to recommend to you, there are many good ones out there.
I choose ATI as many said it good, I used # 085-917246 and ARP bolt
Both to be found
Jegs
summit racing
Old Jan 30, 2021 | 10:03 PM
bwill03z's Avatar
bwill03z
I don’t necessarily think it’s relative to the mileage because I’ve seen ppl have failures with low medium and high mileage cars. Main thing is to keep and eye on it and watch for wobbling and listen for squeaking, at the point you need to change it. This happens to daily driver easy driven bone stock cars not just cars that are driven hard
Old Feb 1, 2021 | 09:17 AM
RetroGuy's Avatar
RetroGuy
Default Pic of properly functioning Harmonic Balancer
Old Feb 1, 2021 | 09:46 AM
MysteryMob's Avatar
MysteryMob
No, pinning it would not prevent the issue, as the debonding does not occur at the same interface as where the pinning occurs.
Old Feb 1, 2021 | 11:16 AM
Chatman's Avatar
Chatman
Unless you are running a supercharger belt, a key or pin isn’t needed, right? The separation isn’t at the shaft as I understand it and we no longer have timing marks on the balancer - the reason for keys in the first place.
Old Feb 1, 2021 | 11:27 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
DO NOT use a GM OEM as a replacement. ATI or Dayco Powerbond will be sufficient. Pin it for good measure.
Old Feb 1, 2021 | 03:36 PM
Tahoe's Avatar
Tahoe
Default Dayco
Does Dayco PB1480SS PowerBond Race Performance Harmonic Balancer fit 2011 G.S./ LS3 ?
thank you
Old Feb 1, 2021 | 03:38 PM
bwill03z's Avatar
bwill03z
thank you
That’s the one I went with
Old Feb 1, 2021 | 04:04 PM
Tahoe's Avatar
Tahoe
Summit website & support tech states that won't fit. That one fits 5.7 & 6.0
thanks anyway
Old Feb 1, 2021 | 04:09 PM
HK770's Avatar
HK770
Believe I 'd go direct to the source !
Old Feb 1, 2021 | 04:40 PM
old motorhead's Avatar
old motorhead
An M6 Grandsport takes a different balancer vs a GS with an auto tranny. Manual GS takes the same balancer as a Z06. I've never had a problem with a Power Bond balancer. If you want to spend more money, there are other options. I agree with above saying there's absolutely no need to pin it unless you're running a belt driven supercharger.
Old Feb 1, 2021 | 05:30 PM
Tahoe's Avatar
Tahoe
thanks motorhead. Do you have a Dayco part #. Dayco said no pulley for dry sump 6.2L. Appreciate your assistance.
To C6 Harmonic Balancer issues
Old Feb 1, 2021 | 05:51 PM
Tahoe's Avatar
Tahoe
Dayco /aftermarket told me they do not make a pulley for a manual LS3 w/ dry sump .
Old Feb 1, 2021 | 06:26 PM
old motorhead
Try this one. PowerBond PB1503SS PowerBond Race Performance Harmonic Balancers | Summit Racing I would call Summit's tech line and make DAMN sure. Their description could possibly be a little more confusing....naaaaaaa, it couldn't be any less clear.
Old Feb 1, 2021 | 06:33 PM
Tahoe's Avatar
Tahoe
OMH you are a gem.......thank you
