08 C6 Starter stuck on
Not gonna lie. The helpless feeling I get when I hear the grind and smell the overheating starter is brutal.
My SWAG (Some Wild *** Guess)
ttt
The suggestion from Dutch08 in the first reply on the thread is something else I considered early in the troubleshooting process, which is that the starter solenoid could be stuck on. But I will admit that getting to the starter on this car is something that is probably the last thing I ever want to do so I’m procrastinating like crazy on it. Plus, due to some other behaviors the car has had leading up to this failure, I have a gut feeling there is an issue with connections in a wiring harness somewhere. Admittedly, that could be an even tougher task than changing the solenoid by the time all is said and done, so if anybody out there has a reason why I should go after the solenoid first, I am open minded.
If the starter runs without pushing the button no matter which relay is in the #43 socket, that means something is activating the trigger circuit for that relay. Verify that with your digital voltmeter, then consult your shop manual to find out what exactly happens when you press the start button. Find the problem and fix it
Here's a couple of WAGS (wild *** guesses):
(1) Throw parts at the problem:
Maybe a bogus start switch is sticking - replace the switch
Replace relay #43 with a new relay
(2) Hail Mary pass & hope for the best:
Maybe the ECU has become confused. Try a hard restart: disconnect the battery for a good 30min - 1 hr. Before reconnecting the battery cables, touch them together to remove any residual voltage and make sure the ECU is dead. Then reconnect the battery and see what happens.
Really don't have a clue without seeing the car and using test equip. Very interesting problem, good luck and let us know how it works out.
When the starter arrived, I installed it and was not entirely surprised when I discovered…..
That did not fix the problem.
The instant I reconnected the battery cables, the security system activated the horn honking and the starter began cranking. What??? How is the run crank signal going when the immobilizer is active? The ignition was not on so the engine didn’t begin running, but I had to pull the relay to get the crank signal to stop. I waited for the ECM/BCM to time out, which it did, so I reconnected the relay. The crank signal had stopped. Cool. I got into the car and tried starting it. Everything was dead.
I went back through the process and double checked my installation of the ignition switch. I found that the harness had not fully seated in the new unit and put it back it place.
Now the system comes back on line and sort of works. Doors, windows, wipers, radio are all dead, although some of them just randomly activate without any input from me. I can’t get a scan tool to work properly. I get errors saying the data is bad.
So, it’s looking like I have a bad BCM. It feels weird to say this, but I pray to God I have a bad BCM. I just want the next repair to be the right repair.
That test gave me the confidence to know that after I had thoroughly cleaned every grounding post on the entire system yet I still had a short to ground, I needed to look for a damaged wire somewhere. At this point I was wishing I was AntMan, because I am way too big to fit into the spaces where all the wiring lives. But anyway I found an area where a wire bundle on the drivers side behind the IPC comes from the engine compartment through the firewall. There is a big piece of rubbery fascia with a hole in it where the wires come through. The fascia is held up in the chassis with some adhesive, which has lost its grip over the years so that now this piece of fascia, which views a few pounds, has just been sawing away slowly at this wire bundle, eventually cutting through the insulation and exposing wires in the bundle. all the wires in this bundle are attached to one of the two 120 ohm terminators that are crucial for maintaining data integrity on the CANBUS network.
So after making that wiring repair, and some mods on the fascia to make sure it won’t damage the wire bundle again, I tested the CANBUS for resistance and voila! Perfect reading of 60 ohms. Since then I have made several test drives and everything on the car works like new, almost. the drivers side window, mirrors and seat position memory are not working, but the interior and exterior door lock switches all work fine. My scanner tells me the Drivers Door Module is non existent. .
I’m still trying to find the issue there. I am stubborn about buying new parts until I am absolutely certain that’s what has to happen. The drivers door module is built into the window regulator and costs about 350. I can see myself buying and installing a new one and still having the exact same problem. Before I order that part, I’m going to unbundle and inspect all the wiring in the drivers door to find the culprit. My biggest fear is that I will find no damage to the wiring, which means I will then need to figure out whether the problem is in the BCM or the DDM, or god forbid both BCM and DDM.
So one of the things I think is really important for others to be informed about,, is the eventual failure of the adhesive that holds up the fascia where the drivers side wiring bundle is tunneled through the firewall. It is an issue that will likely present itself very slowly and is difficult to track down because a problem located right next to a terminator can potentially affect any other electrical system in the car. I suspect it has already caused problems for a shitload of C6 owners. When there is a short in the CANBUS circuit, the issues that result will often be intermittent or otherwise difficult to troubleshoot.
