Check engine is on
Old Aug 25, 2021 | 07:36 PM
Golfer 2325"'s Avatar
Golfer 2325"
Cruising
Default Check engine is on
I have a 2010 coupe with a check engine light on . The code scan reads PO 106 , Manifold Absolute Pressure ( MAP ) Sensor Performance
(Symptom ) - Test Failed DTC clear, History DTC, warning .
Kevin
Old Aug 25, 2021 | 07:44 PM
Purple92's Avatar
Purple92
Ummm... If you're looking for suggestions as to what to do - I would suggest trying to clear the code, and if it comes back - I'd suggest starting by replacing the sensor. The sensor runs $20 - $40, and make sure you replace the sensor seal as well - the sensors don't always come with new seals. After replacing the sensor - clear the codes again.
Old Aug 25, 2021 | 08:04 PM
Golfer 2325"
Cruising
Default Check engine light is on
Thank you for help, any idea how many seniors there are?
Thanks Again
Kevin
Old Aug 25, 2021 | 08:24 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You can just change the sensor but it is an electrical sensor so without checking the electrical portion of the sensor you can only hope the new sensor fixes it !!…you asked how many “seniors” there are…do you mean how many “sensors” there are on the car and why do you need to know how many ??
To Check engine is on
