Help
Old Oct 2, 2021 | 03:19 PM
Basic Black's Avatar
Basic Black
1st Gear
Default Help
Trans in second gear won't shift up or down
fob not detected intermediately interior lite stays on. Heads-up display quit showing what gear car was in But was in second gear Unhooked battery cable twice got in car with fob things back to normal for the time being
Old Oct 3, 2021 | 12:21 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Help
We need more info then just that.
Old Oct 3, 2021 | 02:34 PM
Iceaxe's Avatar
Iceaxe
More info would be helpful... but probably the bushing at either end of your shift cable failed if it's an automatic.
Old Oct 8, 2021 | 08:53 AM
DirtyDicken's Avatar
DirtyDicken
Sounds like two separate issues. Which transmission do you have? (Two different types of automatic went in these cars depending on the year) In my 05 when ether the battery was low or when the alter was near the end of life I would have random electrical issues with lights and the fob like you say you are having. The ECU doesn’t like to have the low volts/amps. From what I found out the early years are more prone to it then later. (My 12 is fine).
Old Oct 8, 2021 | 09:09 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
The OP is a 1st time poster and he posted this question about a week ago .. and has not been back to this thread he started.
My guess is that we won't being hearing from him again.
Another example of a "One Post Wonder" !
Old Oct 8, 2021 | 09:36 AM
DirtyDicken
Gotcha
To Help
