throttle body/pvc issue
Old Nov 20, 2021 | 03:46 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by pnewt
the plastic piece that exits the valve apparently broke off If I found something to insert intot the valve and connect to vacuum line, would that work? A little old to be removing the intake and installing a new one I saw a video where The guy drilled into it to insert a fitting/ Really appreciate your help in this. Wonder why it runs perfectly anyway. brought car home like this in a 2hour run???
By the time you mess around with trying to patch together an improvised repair like this (and possibly having to do it more than once if the first attempt fails) you'll have likely spent more time than if just replaced the intake manifold.
Trust me, do it right as it's not that difficult and the manifold isn't that expensive.
