LS3 F35 cam Issues
Old Feb 3, 2022 | 10:19 AM
Lucas_C6's Avatar
Lucas_C6
Originally Posted by slowtealz28
Ported rod mod LS3 intake... didn't think of that before, have they tried putting a stock intake on to see if that helps at all?
We have not swapped manifolds yet on it. We haven’t had much indication but not saying it’s not possible I guess.
Old Feb 3, 2022 | 04:30 PM
slowtealz28's Avatar
slowtealz28
The only reason I am bringing that up is I've seen guys have tuning issues and it ends up being traced back to a faulty part or gasket. If you can find one to swap I would definitely consider it.
Old Feb 3, 2022 | 05:31 PM
Dano523's Avatar
Dano523
It is a SLP Blackwing intake
Short version, put the stock air system back on the car, and you will see the problem go away.
The stock air system already outflows the engines needs in the first place, and was designed so the Maf sensor location always is getting clean reading of air through it, no matter the RPM range of the car.
On a great deal of aftermarket intake system, lets just say that the placement of the Maf sensor locations on them, not in a clean air path of the system through out the entire range of air for the motor will be pulling in for the entire RPM range, and you end up with all kinds of reading problems from the Maf instead (again, your problem at hand).
Also to point out, since the air filter of the after market system is pulling in the air from the same location as the stock air filter system, the system you have in the car is not a cold air system to start with.
Old Feb 5, 2022 | 08:50 PM
Lucas_C6's Avatar
Lucas_C6
Originally Posted by asd_srt
Let us know how it goes. I have a vararam on my car and it's had 4 cams now. I've also tuned a few vararam f35 cars. What lifters and pushrods did you get? Heads milled at all? Checked the rockers?
Unfortunately after swapping my intake to the Vararam system, it made very little improvement. Just a update like I said I would give.
Old Feb 5, 2022 | 08:59 PM
Lucas_C6's Avatar
Lucas_C6
Unfortunately I do not have the stock system anymore and have since thrown that system away. I am now running a Vararam OTR intake that pulls from the bumper vents. As well as the system also comes with a maf housing to help with smoothing the air. The problem has improved slightly but not fully by any means. I would not really like to run a stock system due to power loss. At this point in the game I am unsure of exactly what the issue is, as I understand the MAF readings are off but if the cam specs are to aggressive then down low it can possibly just simply have to much overlap causing the issues. I would love to hear from other people who are running the F35 cam and see if they are running into similar issues or not.
Old Feb 6, 2022 | 01:14 AM
Dano523's Avatar
Dano523
Simply, if cam is causing all the intake air turbulence due to the wicked over lap that can not be solved at the MAF, or tune to clean up the Maf flow reading, then worst case, car gets tuned in open loop to solve the problem isntead.
Old Feb 7, 2022 | 03:28 PM
Lucas_C6's Avatar
Lucas_C6
The car has been tuned already once in speed density to bypass the MAF entirely, and still does the stuttering/breakup. We have had the car tuned 3 different times so I am truly completely lost as for what the cost could be.
Old Feb 14, 2022 | 11:28 AM
Lucas_C6's Avatar
Lucas_C6
I had Vengeance Racing re-tune it and they fixed the issue entirely. It ended up being a enrichment issue. Just a update.
Old Feb 14, 2022 | 11:29 AM
Lucas_C6's Avatar
Lucas_C6
Old Feb 14, 2022 | 11:30 AM
Lucas_C6's Avatar
Lucas_C6
tossing a random misfire code? or has a noticeable miss that you can hear/feel
Where in NC are you I'm in the Fort Bragg area and tune a lot of stuff I can check it out if you're localish. Or recommend someone who can.
Old Feb 14, 2022 | 05:18 PM
old motorhead's Avatar
old motorhead
Glad you got it fixed
Old Feb 16, 2022 | 03:30 PM
slowtealz28
Very cool, wouldn't have expected that to fix it with how many times its been tuned. Thats awesome though glad it worked out.
Old Feb 16, 2022 | 04:40 PM
  #33
old motorhead
I think that goes back to how difficult a rig with a cam like that is to tune. I ran around on the stock tune for quite a while after I added heads and a much milder cam. Stack a bunch of overlap in there and your tuner had better be damn good.
Old Feb 19, 2022 | 01:58 PM
  #34
d16dcoe45's Avatar
d16dcoe45
Out of curoisity did you drive any big cammed cars before deciding on the F35? It's a pretty big cam, if 3-4 shops are all saying the same thing.... you're probably gonna have to live with it unless you wanna keep throwing more and more money to tuners. Big cams come with quirks, some worse than others.
In the whole scheme of things, F35 is a baby cam. I have a GPI SS4 NFC in my LS3 which is a bit larger and I have NO such issues, however it took ALOT of street/drivability tuning to get it to play nice!
Old Feb 19, 2022 | 06:27 PM
  #35
old motorhead
Damn, in what scheme of things is a cam with .650 lift and 20 degrees of overlap a baby cam?
Old Feb 21, 2022 | 11:11 AM
  #36
grinder11's Avatar
grinder11
.650" lift and 20° overlap do not a baby cam make. At least in my neck of the woods!!
Old Feb 22, 2022 | 07:04 AM
  #37
Dano523's Avatar
Dano523
So is other tuner(s) giving you your money back for the 3 different tunes that they did not solve the problem, but Vengeance Racing did?
To LS3 F35 cam Issues
Old Mar 5, 2022 | 11:00 AM
  #38
LSXANGEL's Avatar
LSXANGEL
8th Gear
have you checekd valve springs i had the same issue on my old car lsa g8 and i had a broken valve spring thankfully i had the tsp 660 dual kit so that saved the motor lol but i would check there too.
Old Mar 6, 2022 | 07:44 PM
  #39
Lucas_C6's Avatar
Lucas_C6
Yeah I checked everything mechanical and electrical, it turned out to be a tuning issue. It took 4 tuners but finally got one who got it fixed.
Old Mar 8, 2024 | 12:39 PM
  #40
LS7_guy's Avatar
LS7_guy
Curious what where the new WHP/WTQ numbers with the F35 and ported heads.
I have the SS3 Cam and LS3 ported heads, stock intake. Looking to bump mine up some.
