C6 Base Vararam
Old Feb 28, 2022 | 10:23 PM
gibby1348's Avatar
gibby1348
5th Gear
Default C6 Base Vararam
Thinking about adding the Vararam snake charmer. All stock except axle back Corsa extreme. My question is will it throw any codes and does a tune need to happen with it. Any Other pro/cons. I am aware of the potential hydro lock as a con.
Old Mar 1, 2022 | 12:06 AM
Evilbeard's Avatar
Evilbeard
no, it doesn't actually put any more air into the car, it just makes it easier for your car to suck in the air. Better flow leads to better performance. You shouldn't get any codes if everything is installed properly.
Old Mar 1, 2022 | 08:00 AM
blownbayou's Avatar
blownbayou
I would try to find a Z06 air bridge for 50-70 dollars..... You could also do the shroud mod if you wanted to get that better flow into the intake.
Old Mar 1, 2022 | 09:59 PM
4SUMERZ's Avatar
4SUMERZ
I installed the newer style Vararam in my Z51 optioned 2006, with the precut shroud, silcone hose before the MAF and the silicone hose to replace the accordion before the throttle body. No codes, and no tuning required.
Old Mar 6, 2022 | 11:51 AM
wood78221's Avatar
wood78221
I have one and no issues. I guess if it was going to take water in through it you would be sitting in water already
To C6 Base Vararam
