Swapping LS3 valvetrain to LS7
Old Mar 30, 2022 | 10:08 PM
Z97's Avatar
Z97
Cruising
Default Swapping LS3 valvetrain to LS7
Curious as to those who know about this swap... The old google/facebook/youtube search isn't getting me too far with this one.
Have a LS3 being stroked out to a 416 build since it decided to spin a rod bearing (good times). Based on what I know the bore has to be 4.1 to run LS7 heads? Or there abouts?
Is it worth while to go LS7 valvetrain for extra power? Heads are currently stock casting ported by texas speed.
Any reading material or insight is appreciated!
Old Mar 31, 2022 | 09:11 AM
Orion2011's Avatar
Orion2011
Not 100% sure but I don't think they are compatible. LS3 is 4.4" spacing
Old Mar 31, 2022 | 07:19 PM
farmington's Avatar
farmington
Ls3 bore is 4.060. You can’t bore them .040.
Old Mar 31, 2022 | 08:35 PM
old motorhead's Avatar
old motorhead
As far as the valve train goes for the two engines, the lifters and some valve springs are interchangeable. That's about it.
Old Mar 31, 2022 | 11:24 PM
KW Baraka's Avatar
KW Baraka
Uh.....yeah.....it's been done.....LS7 heads on a bored/stroked LS3.
All this talk of LS7 heads requiring 4.100 bore is GM disclaiming so they're not liable for any damages.....
LS7 heads on a 6.2l block 4.07 bore. | Yellow Bullet Forums
KW
Old Apr 1, 2022 | 08:08 AM
grinder11's Avatar
grinder11
ALL LS, LT, SBC engines are 4.400" bore spaced. It's the smaller diameter of the cylinder that has interference with the large 2.200" diameter LS7 intake valves. IMHO, the OP would be way ahead of the game using ported LS3 heads, or aftermarket.......
To Swapping LS3 valvetrain to LS7
