Getting P0101 CODE & Service traction System
Old May 30, 2022 | 03:34 PM
91vettezr1's Avatar
91vettezr1
Default Getting P0101 CODE & Service traction System
Hi
Recently had cam, head work ,fast intake done on a 2008 z06 8k miles . Car is making 536 RWHP, The car was running great until I installed headers and Corsa intake. I am getting a P0101 code and "Service traction system". I replaced MAF sensor ,replaced all plugs, checked wire connections to plugs and coils. The car doesn't run horiible when I drive it but it definitely not running right.Rough idle, plugs get soot on them.
I am taking it back to the shoP[ (CARTECH) who did the work in the next 2 weeks. I am hoping a retune since the headers were installed will fix the problem. I waNTED to solve the problem prior to bringing it in for retune. Any thoughts or suggestions? I searched a bunch of threads but no luck. UPDATE: decided to remove corsa intake and re-install factory intake. I was shocked but car ran better and no codes,I will swap filters and see if that changes anything on the corsa. Really like the look of the corsa
