P0430 code
Old Jun 24, 2022 | 12:20 PM
cgladish's Avatar
cgladish
Default P0430 code
not sure if i've ran this out before ( if so, my apologies ). i've had a P0430 code for quite a while now ( since last 11/2021 ). i've replaced the downstream O2 sensor & passenger side cat.
i ran a live data check this morning:
Cat 1 was @ 1054.4°F, Cat 2 @ 982.°F.
O2 sensor readings:
B1S1 (V): .755
B1S2 (V): .720
B2S1 (V): .825
B2S2 (V): .735
does any of this point to any issues? any ideas of what else to look for? i've put on about 5k miles and the car feels fine ( no noticeable loss in power or mpg ).
Old Jun 24, 2022 | 01:51 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Have you measured with thermometer laser how hot your Cats are getting, any muffler shop will do it for you for free, thinking there get the job.
When I had right Cat, with check engine light, the temperature was above 400 degrees, and the left was cool temperature.
My car was 2005 at the time with 73,000 miles.
Old Jun 24, 2022 | 01:55 PM
cgladish's Avatar
cgladish
I listed the cat temps above ( drivers side 1054° / passenger 982° ). less then 7% variance, not sure if that means anything. passenger cat was replaced in nov / 2021.
Old Jun 24, 2022 | 02:06 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
I saw go to Muffler shop, that's what they do for living, and your Passenger side is hot, and blocked?
Old Jun 24, 2022 | 02:10 PM
cgladish's Avatar
cgladish
i might end up going back the muffler shop. it's just the CEL was on before and, is still on even after the cat install.
Old Jun 24, 2022 | 02:32 PM
Spaceme1117's Avatar
Spaceme1117
There are a number of things that can cause a P0430. Cat going bad for sure but base on the temps, I doubt its your cats.
Check your air intake and your intake clamps to make sure everything is seated and sealing. Loose intake manifold can leak and cause problems. Leaking exhaust also can cause this so check exhaust gaskets, header or manifold bolts for looseness, check connections in the exhaust. O2 sensors can sometimes get loose and back out which can cause this code.
P0430 is a code for the cat on the passenger side and if that was replaced, I would bet you have a leak in the exhaust system somewhere on that side.
Old Jun 24, 2022 | 03:31 PM
cgladish's Avatar
cgladish
if it is an exhaust leak, it would be small one ( at least nothing audible anyways ). can try the old carb cleaner and spray around the intake and hoses.
Old Jun 25, 2022 | 08:15 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Leaks around the intake will NOT cause a P0420/0430...do your downstream O2 sensors switch or oscillate like the upstream...they should not...front should not look like the back !!...when the cats are hot and at 3000 RPM they should be steady anywhere from 700-800mV...you may have an exhaust leak somewhere...I use a shop-vac with the outlet hose switched around so it blows out...you can use a soapy water solution to find the leak.
Old Jun 27, 2022 | 10:13 AM
cgladish's Avatar
cgladish
https://youtu.be/zQ8BXAwK-QY
i thought about it after i sent my response and, did realize, like you mentioned above, that checking for intake leaks would not provide the answer on the CEL. as i do not have easy access to myself, i'll check the shop that did the cat install and see what he can provide.
thanks the info.
Old Jun 27, 2022 | 01:23 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Keep us posted of what you find to repair the car.
Old Jun 27, 2022 | 01:34 PM
cgladish's Avatar
cgladish
Will do. all four of the O2 sensors appear to be within mV range ( at least at idle. shown on previous post ). I'll also check under load or at least elevated rpm's.
short of that, a trip to the muffler shop is next.
Old Jun 29, 2022 | 03:49 PM
C6VetteLover's Avatar
C6VetteLover
Another thought, was the replacement cat a factory or factory equivalent or some kind of cheap aftermarket? Some O2 sensors are just on the boundary line for working with a stock cat but an aftermarket that isn't well designed or flows considerably more than factory may trip it. When I replaced the downpipe on my old 02 Grand Prix GTP I had installed a ZZP high flow catted downpipe and was getting a code for a faulty cat, when I took it to the shop they checked and said it was a weak 02, replaced with a new AC Delco and problem went away.
Old Jun 29, 2022 | 03:56 PM
cgladish's Avatar
cgladish
[QUOTE=C6VetteLover;1605341336]Another thought, was the replacement cat a factory or factory equivalent or some kind of cheap aftermarket? Some O2 sensors are just on the boundary line for working with a stock cat but an aftermarket that isn't well designed or flows considerably more than factory may trip it. When I replaced the downpipe on my old 02 Grand Prix GTP I had installed a ZZP high flow catted downpipe and was getting a code for a faulty cat, when I took it to the shop they checked and said it was a weak 02, replaced with a new AC Delco and problem went away.
i had the code prior to the cat install. even after the install, the CEL remained. initially i replaced the downstream O2 sensor, then the cat. i still haven't ran live data under load but, at idle, all 4 sensors, are within mV range.
I'm going to make an appointment within the next week, to get into the muffler shop. have him snoop around checking for exhaust leaks. at this time, this seems the most likely culprit.
i've got till December to figure it out ( registration and smog test ).
Old Jun 29, 2022 | 10:17 PM
adabiri2's Avatar
adabiri2
Hold on. You push air up muffler to check leaks? Damn thats a good idea, sob..
Old Jul 7, 2022 | 09:53 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
[QUOTE=cgladish;1605341376]
Any updated yet, the rest are interested in your finding.
Old Jul 7, 2022 | 10:55 AM
cgladish's Avatar
cgladish
[QUOTE=1bdvet;1605373471]
assuming that this was directed to the OP but, i also had a comment embedded within that message too ( second half of the note ).
in case it to me, I'm still waiting to get the car into the shop for an overview.
if your note was to OP, I'll, just wait on the sidelines.
To P0430 code
