ls7 rod length
Old Sep 28, 2022 | 10:14 PM
905Shooter's Avatar
905Shooter
Default ls7 rod length
Long story short my ls7 spun some bearings, i’m able to reuse the crank and block and i’m going with a forged rod and piston setup. I’m not really trying to spend over 1000 for a rod set and another 1000 for a piston set. I was looking at texas speed or callies comp star forged rods and maybe wiesco pistons. All of the rods i see are 6.125” long but i’m seeing on the forum the stock rods are 6.067” would i be okay running a 6.125” long rod with a piston that has bigger valve reliefs or how does that work? Also going with a set of prc heads if that changes anything.
Old Sep 29, 2022 | 12:17 AM
jayyyw's Avatar
jayyyw
You need to get pistons that match the rod length. 6.125" (Aftermarket) or 6.067" (LS7 length).
I'm selling some Wiseco pistons that are made for the LS7 rods, if you are interested.
Old Sep 29, 2022 | 09:07 AM
ClothSeats's Avatar
ClothSeats
I could be wrong, but I don't think any of the aftermarket forged steel connecting rods, including the Callies Compstars, will work with the OEM LS7 crankshaft. You will need to buy an aftermarket crankshaft as well. It is best to buy a matched and balanced rotating assembly (crankshaft, connecting rods, and pistons). That might be a blessing in disguise anyhow. Reusing that crankshaft after spinning bearings might end up being way more trouble than it is worth.
Old Sep 30, 2022 | 01:50 PM
Red Greene's Avatar
Red Greene
I have a set of stock ls7 rods , PM me if intersted.
Old Sep 30, 2022 | 04:35 PM
RACER7088's Avatar
RACER7088
Re-balancing an OEM LS7 crank after changing to steel rods is basically not a good idea as the balancing generally costs more than a decent aftermarket crank.
Nowadays both Callies and SCAT have made 8 counterweight forged cranks both in American and in Import steel forgings that are really nice and are far better than the oem or most aftermarket 6 counterweight cranks as well.
These also have no problem balancing with aftermarket rods and pistons at all.
Old Sep 30, 2022 | 08:22 PM
jayyyw's Avatar
jayyyw
Yup, you can use aftermarket rods on the stock crank but as mentioned above, balancing becomes very expensive. My engine builder just built one with aftermarket rods and pistons. The balancing charge was over $800.
Old Jul 16, 2023 | 01:47 PM
Anthonyp52's Avatar
Anthonyp52
1st Gear
do you still have these rods available
To ls7 rod length
