6l80e problem
Old Oct 6, 2022 | 02:00 PM
Mattoc6's Avatar
Mattoc6
Navigator
Default 6l80e problem
Hi all I have an’08 C6 ls3 auto which has a gearbox issue, it has no forward gears but does have reverse if I pull the TCM fuse it will go forward in all gear position, I took the pan off and the valve block to see if the check ***** had got stuck in the gasket put all seems well. The oil seemed ok and not burnt scanner shows no faults any ideas what the problem could be? Thanks
Old Oct 7, 2022 | 09:20 AM
pcguy2u's Avatar
pcguy2u
TTT - bump for ya
Old Oct 10, 2022 | 04:53 PM
Mattoc6's Avatar
Mattoc6
Navigator
Cheers, I’m thinking it maybe the 1-4 piston as the check valves where ok but I’ll have to strip the box to find that
To 6l80e problem
