quicker Manuel shifting
As for faster shifting manual trans, then your looking for a sequential trans instead.
The down side, straight cut gears, so lots of gear whine, very easy to over rev when banging back down on the trans, and not cheap. note, can be either still stick, or converted over to lever button shifting instead..
A sequential is the (expensive) correct answer.
Yes, clutch still needs to be use, as well as the shifter lever...
Cutting the ignition, the way the WOTBOX is doing when well programmed, helped me to bring the shifting time in a shorter zone...and I use it only, when necessary, on recorded runs.
What I found really intriguing and remarkable is the % of diminished efforts to upshift with the WOTBOX...
I would never force a shifter to engage a gear up or down, since 50+ years.
This is not an alternative to a sequential gearbox manage nowadays by a very similar electronic system to N2MB in the principle, and the WOT Upshifting has some positive on supercharged engines, but also some attractive effect on NA engines.
I exposed an alternative that some might consider.
Christian
