BCM From Newer Corvette
Old Jan 3, 2023 | 05:18 PM
mtchcnner's Avatar
mtchcnner
3rd Gear
Default BCM From Newer Corvette
My BCM got wet in my 07 Corvette and it looks like that part is discontinued now. Cultrag has new BCM's for sale but theyre for the 2008-2013 corvettes. Does anyone know if those BCMs will work on the older C6's as long as they're programmed? Or are they completely different?
Old Jan 3, 2023 | 07:51 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Welcome to the Forum !!…your best bet would be to drop by your local Chevy dealership and ask someone in the parts department…they would give you the best info as far as part numbers.
Old Jan 4, 2023 | 02:56 PM
CroOrange's Avatar
CroOrange
I would buy a second hand BCM from a junkyard and be done with it. You sure your BCM is dead?
Old Jan 4, 2023 | 03:04 PM
mtchcnner's Avatar
mtchcnner
3rd Gear
I took it out and used some rubbing alcohol and baking soda/water mixture to clean the board up. It was corroded at the top left. It fixed the majority of the issues but a couple of times now I’ve had the car not start and no power at all. I would have to take the negative terminal off the battery and put it back on then the car would start. I’m thinking either I need to clean it a little more or the bcm is done.
Old Jan 5, 2023 | 06:02 AM
CroOrange's Avatar
CroOrange
Oh, you should have dried the board completely before giving voltage again. Boards soak up water, you need to dry it correctly before using it again.
If you aren't in electronics, you can find some shops that will clean & dry it for you. For example: http://www.us-tech.com/RelId/2116467...B_Cleaning.htm
Anyway, second hand BCM would be my choice.
I think you would be looking for the GM Part: 25790451. It should be written on your BCM. You have one for sale on eBay coming from Latvia:
https://www.ebay.com/itm/15531954872...Bk9SR66wuJmwYQ
Where are you based in the US? The BCM above comes from a manual LS2 2007
Old Jan 5, 2023 | 08:48 PM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Call patrick at Cultural and talk to him ... he is more knowledgable than 90 percent of the dealer parts people.
Old Jan 6, 2023 | 05:05 AM
CroOrange's Avatar
CroOrange
I somehow have the impression that we won't be seeing Mitch again.
By the way I believe the intent was Patrick from Cultrag, cultural is probably the autocorrect kicking in
Old Jan 6, 2023 | 01:21 PM
mtchcnner's Avatar
mtchcnner
3rd Gear
Appreciate all the input guys, I took the board back out and sanded down a little more corrosion on some of the pins at the top left of the board, rinsed it off again and let it dry really good this time. So far so good, haven't had that random starting issue again.
Old Jan 6, 2023 | 03:40 PM
CroOrange's Avatar
CroOrange
You know you can pay an electronic shop 100$ and they will stabilize the board for you? Not radioshack, a real shop.
I would still consider getting the second hand BCM because the board is bound to die one day. just FFT.
Old Jan 8, 2023 | 10:56 PM
KennyPowers's Avatar
KennyPowers
Just got the last new bcm in the country for my 09 flood car.. Ian will no doubt make it difficult to find one.. i think contemporary corvette had one used $300.. Chevy said wait time was about 6 mos, got lucky someone ordered mine and didnt wait to get it i suppose.. GL
u can try car-part.com start calling around
AES corvette
or
Autowerks Inc corvettes
Old Jan 13, 2023 | 05:19 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by TCW
You're joking right?
Tom
AHHHH, NO !!….who is going to trust to give you the latest part number…some Forum member or aftermarket vendor…LOL ??
Old Jan 13, 2023 | 05:24 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Originally Posted by C5 Diag
AHHHH, NO !!….who is going to give you the latest part number…some Forum member…LOL ??
I agree! After rereading your post, My bad!!
I DID delete my post.
Sorry
Tom
To BCM From Newer Corvette
