2006 Auto does not enter Accessorry mode
Only a short messsage " No Fob detected" while I am pressing the start button .
Nothing happens besides clicking in the relay 42 in engine bay when activating the start/stop button
When I try to talk to the BCM,ECM,TCM with my Tech 2 or my SnapOn scanner both get no communication will these modules so I think this is due to they are not powered up.for some reason .
Communcation with RCDLR or door/seat mdules on thw low speed serial bus works fine .
On the schematics below it seems lik the BCM is powering up these highspeed modules through term C1:22 .
Or is it maybe C1:C that supplying these modules with power .
All fuses in engine bay and passenger footwell seems to be ok.
Does anyone know which outputs from BCM shall be energized when the start button is pressed for min 5 sec into accessory mode ?
Can my friends BCM dead and need replacement ?
If anyone with C6 knowledge on this issue I will appreciate any input on whe to check/look
Yes . I have this breakoutbox and I measured these CANBUS Low and High signals on my daughters Volkswagen (for fun) last years so I am a bit familiar with these signals .
I can do these measurements on my friends C6 .
I do not understand why I not can communicate with the BCM , but if the High speed LAN is down maybe the BCM is affected if the scanner user canbus com with the BCM instead of serial com
As far as I know the BCM is master of the canbus and I have to measure with my scope and multimeter:
Ignition OFF : approx 60 ohm between Can Low and Can High (Due to one 120 ohm resistors in each end of the can bus lines .
Ignition ON: 2.5 volt between CAN low and Ground
My big problem is that I get no ignition ON ( no accessory volt) when using the button .
I will report back when I have done these measurement and verified the BCM voltage feedings , may one is missing and causing the BCM to stop working
Until you can get the car in accessory mode or ignition-on mode, you won't see stuff on the CAN bus. If I'm understanding your symptoms, it seems like you have a fob/RDCLR problem to address first.
Could a lack off Ignition 1 voltage from the RCDLR term C1:C stop a Accessory voltage from the BCM and secondly a non operating canbus between high speed modules ?
I think I put my words wrong with this question "Between RCDLR term C1:C and BCM term C4:C8 ?"
The BCM need to see battery voltage on the C4:C8 term. If the RCDLR is not providing a 12volt , my suggestion is a bit brain dead
I will try a fused jumper from the battery directly to C4:C8 on the BCM and see if I will be able to activate ACCESSORY MODE using the button.
If so happens and the canbus com is working my enemy to fight is the RCDLR module .
We have a spare unit I can program with my TIS2000 software on my laptop if needed .
Have only done reprogramming of my C5 PCM unit and the Thefte relearn
I will report back after monday
So either TIS2000, or TDS, go into RCDLR module in that module select screen in either, and put the RCDLR into relearn mode.
Going to get a 3-10min count downs in the DIC, and when the count down gets to zero each time, press the starter button down side, to start the next count down. Once you are done with the third 10 min count down, RCDLR will be in Fob relearn mode, and can program a fobs in now.
Myself,will just program in the first fob that way, to allow the car to now go into other modes, and then using Tech2win to program in the last of the fobs.
And next time, use Tech2win to do the fob erases, then program in the fobs using Tech2 win at the same time, while the BCM is still in either ACC mode, or Run mode with the motor off (just hold down the starter button on the bottom side for 5 seconds to get into the later mode). Hence problem is the BCM, and when you put the car back into off mode, RCDLR is not going to allow it to come out of that mod (short of setting the RCDLR back into relearn mode, so fobs can be programmed into it again).
As for which to use, if car BCM is set to USA for country of use, TDS every time, since TIS2000 is always going to require the 30 min count down/three starter pushes to get it back into count down mode, while TDS relearn method, no count downs.
Abound models, going to have the three 10 min count downs with either software used.
The car is a US car imported to Norway a few years ago.
I will do the TDS programming with TIS2000 tomorrow and report back .
As for once you get a fob programmed in and put the car into ACC mode, using Tech2win to go into BCM set up, and check to see what country of use the BCM is set up to. If set to USA still, then TDS is the better program, since it will not have the 3-10min count downs before you can program a Fob into the RCDLR once set into relearn mode.
I know the RCDLR is communicating along the singleline serial bus(working using Tech2) and the BCM,TCM,ECM and EBCM using the highspeed CANBUS.
To me it looks like SPS is trying to use the Canbus com to communicate with the RCDLR modul, but this communication will not work until Accessory mode(Igntion mode) is enabled bye the BCM .
Is it any change in settings needed to tell TIS2000/SPS to communicate with the serial databus so I can program the RCDLR into learning mode
When I use Tech2 standalone I can view RCDL data
When I choose Setup New RCDLR under keyless data I get this com error .
I a way similar to the SPS respons
