Oil Catch Can Question
Old Aug 3, 2023 | 10:02 PM
  #41
C6 Motorsports's Avatar
C6 Motorsports
Originally Posted by gpruitt54
Great! Looking for a spacer like you used. From where was the pipe used prior to using it here? What is the OD and ID of the pipe you used?
It was just some spare anodized aluminum tubing I had laying around. Any pipe larger than your 6" bolt will work just fine.
Old Aug 4, 2023 | 07:54 PM
  #42
gpruitt54's Avatar
gpruitt54
Thanks. I ordered a bit of aluminum thick walled tube with a 10mm hole. It arrived today. I will start mocking up the length of the tube as you did. So finally, what are those fittings you used? There are no? Are you using those fittings at the engine end of the tubes?
Old Aug 5, 2023 | 12:04 AM
  #43
C6 Motorsports
It's just fancy 3/8s hose that came with the catch can, they included metal end caps, you don't really need them.
