Oil Catch Can Question
Old Jul 17, 2023 | 04:12 PM
gpruitt54's Avatar
gpruitt54
Default Oil Catch Can Question
I was at a Corvette car show this weekend. A guy was talking about an oil catch can we installed on his C5 and his C6. Looked on Amazon and say lots of catch cans. Which one to buy, and how do you mount the device in the engine compartment?
Old Jul 17, 2023 | 05:27 PM
Aardwolf's Avatar
Aardwolf
I have one from here https://www.saikoumichi.com/ the have explanations and pictures. Several threads about this recently with more info.
Old Jul 17, 2023 | 05:45 PM
TucoTom's Avatar
TucoTom
I have an Elite Engineering catch can, I recently emptied about an inch of oil over a 7500 time span.
Old Jul 17, 2023 | 06:25 PM
gpruitt54's Avatar
gpruitt54
For what a catch can does, I cannot see spending more than $30-to-$50.00 for one. I am not racing or competitive driving. So, inexpensive is the word of the day here.
Old Jul 17, 2023 | 07:49 PM
Spaceme1117's Avatar
Spaceme1117
I used to think the same thing. But you do get what you pay for.
I have had Elite Engineering catch cans in the past and they are good.
But Might Mouse is the way to go. Not cheap but they are top quality and have multiple mounting solutions. I also like that the MM catch can will replace your PCV valve of your engine. It works very well, better than the stock system which prevents oil in the intake.
Old Jul 17, 2023 | 11:17 PM
gpruitt54's Avatar
gpruitt54
For street driving, not racing, autocross, or other competition driving, these cans are mostly made of nicely machined anodized aluminum, and they all collect oil. Don't see where hundreds of dollars on such a device is worthwhile for my specific needs. I am curious as to where and how to mount these devices of whatever level?
Old Jul 18, 2023 | 08:12 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
What year C6 do you have?
Automatic or manual transmission?
Plumbing of the lines is going to be different between the wet sump LS engines and the dry sump LS engines.
Old Jul 18, 2023 | 02:38 PM
gpruitt54's Avatar
gpruitt54
Mine Vette is a 2006 C6, Coupe, Automatic, LS2, Cold Air Intake, the rest of the car is stock. Thanks
Old Jul 18, 2023 | 03:46 PM
Turbo6TA's Avatar
Turbo6TA
Easy and effective way to plumb your LS2 with the wet sump oil system is shown below:
This will pull dirty crankcase gasses / fumes from the valley cover (through a metered orifice built into the valley cover nipple) and route it into the inlet of your catch can. These fumes will be cleaned of oil by the catch can, The gasses will then be routed to your intake in back of the throttle body (this is a vacuum port) ... Because you are pulling air (crankcase fumes) out of the crankcase, you will need a way to replace that air. That is the purpose of the tube going from the rubber bellows (just in front of the throttle body) to the passengers side valve cover. This filtered clean air then replaces the oily dirty air that was pulled out of the crankcase by way of that valley cover nipple.
Really a very simple but effective system ... and if you have a good quality catch can, you won't be pulling all that dirty oil into your intake manifold anymore.
Old Jul 18, 2023 | 11:36 PM
gpruitt54's Avatar
gpruitt54
Thanks for the clear the concise explanation and illustration. It now makes since how to do the plumbing. Aside from quality hoses, what makes a "Quality" and economical catch can? I am looking at the Amazon offerings, all under $50 dollars. For example:
https://www.amazon.com/dp/B09RFGDSJ5/ref=sspa_dk_detail_5?psc=1&pd_rd_i=B09RFGDSJ5&pd_rd_w=VvzyB&content-id=amzn1.sym.0d1092dc-81bb-493f-8769-d5c802257e94&pf_rd_p=0d1092dc-81bb-493f-8769-d5c802257e94&pf_rd_r=V7H0QEA8EMAW0PH76XXJ&pd_rd_wg=Y6B0x&pd_rd_r=c51bfda9-6d7e-4c49-8439-f78abf876414&s=automotive&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWwy https://www.amazon.com/dp/B09RFGDSJ5/ref=sspa_dk_detail_5?psc=1&pd_rd_i=B09RFGDSJ5&pd_rd_w=VvzyB&content-id=amzn1.sym.0d1092dc-81bb-493f-8769-d5c802257e94&pf_rd_p=0d1092dc-81bb-493f-8769-d5c802257e94&pf_rd_r=V7H0QEA8EMAW0PH76XXJ&pd_rd_wg=Y6B0x&pd_rd_r=c51bfda9-6d7e-4c49-8439-f78abf876414&s=automotive&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWwy
Old Jul 19, 2023 | 09:42 AM
Turbo6TA's Avatar
Turbo6TA
I know nothing about the catch can you posted a link to, but if you get that can, make sure you purchase it without the breather.
Old Jul 19, 2023 | 10:45 AM
gpruitt54's Avatar
gpruitt54
Yes, I am looking at the models without the breather. Thanks.
Old Jul 19, 2023 | 01:50 PM
Sayfoo's Avatar
Sayfoo
I don't see any use for this unless you have a lot of blow by. Won't hurt anything, but no advantage on a well running street car.
Old Jul 19, 2023 | 02:26 PM
gpruitt54's Avatar
gpruitt54
My car runs well. However, I understand that there can be some amount of oil that gets into the intake and into the combustion chamber. For what I plan to spend for a catch can ($50 or less), it seems like a benefit. Just found this one for my 06 Coupe with an LS2 engine.
https://www.ebay.com/itm/204055375910?hash=item2f82a5f026:g:oaIAA OSw3QxjSMwI&amdata=enc%3AAQAIAAABAFflt6n aCTP4dq%2Bf2o0bSU84RMrXXaeV12X3i0tXdQz6T C7ZF7yD924NhY8kXi%2FEnF9VIgxyhrjSGVFtTVN CU5%2B4T%2F4NH2PpvdAyj7fmdSCN%2BTS1h6UnG FHtKalhmhbQZYKvZZx0K91WlQ1OrB0Sxamx8LkCu I8201F%2FQyI1Nr0IEr5WeWFLAJpbCCpDgE8Lyud p%2FDfjna1vsdMH6V7PLu2p8lnJcOCJdW95voMiB bP4qoCt9TSZGTDX9bJ0rr2yHVH%2FDeyLDkPINnG iAvkmLVeBLDQJfomYbt4dePzNP5VatllVe9lb5iV ZEWVXcKetlavK5ExC2ZeCROI9UqWmJZ0%3D%7Ctk p%3ABFBM5qu-9q1i
Old Jul 19, 2023 | 02:43 PM
Turbo6TA's Avatar
Turbo6TA
Have you ever removed your throttle body and looked inside your intake manifold ... you will see lots of oil laying in the bottom of it.
All these LS engines have that problem. A catch can can alleviate most of it.
In my case, I have a Magnuson (PD) supercharger installed on my engine. I don't want all that oil getting down in the supercharger and gunking up the rotors.
___________________________
True .. If you have a worn out engine with lots and lots of miles, or maybe a cracked piston ring land causing excessive blow-by, a catch can won't fix anything. Most of our engines don't fall in this category.
My catch can:
Old Jul 19, 2023 | 08:39 PM
wjnjr's Avatar
wjnjr
The Mighty Mouse catch can is very well made and provides the best available liquid recovery from blowby gasses.
Check them out here:
https://www.mightymousesolutions.com/
Nice installation
Old Jul 20, 2023 | 06:33 AM
Spaceme1117
If you are only willing to spend $50 or less, just don't even bother. Any can that is $50 or less will be a piece of junk that is likely cause more problems than just staying stock.
There is a reason why people who know recommend Mighty Mouse; we've been down the cheap road before and you end up spending more in the end than if you had just paid more for a quality part in the first place.
To Oil Catch Can Question
Old Jul 20, 2023 | 08:27 AM
gpruitt54's Avatar
gpruitt54
It's a can that collects oil and uses rubber lines. I have not heard or seen how a $200 can does something that the $50 can cannot do. If the $50 dollar machined aluminum can melts or something, then maybe I will look at a more expensive option. My car is a street car, not a race car. Don't need race / aerospace quality gear.
Old Jul 20, 2023 | 11:58 AM
Sayfoo's Avatar
Sayfoo
Did you miss the part about a good running street car?
If you must get one, be sure to get a red one. It will add at least 15hp. A black one (same model/brand, just black color) will only add 10hp.
And stainless steel braid hoses(adds even more hp than even a red hose), special hose clamps, etc. to get the maximum hp gain.
And mount it in the most conspicous place posible so it really stands out when you open your hood, to get another 2-3hp.
Old Jul 20, 2023 | 12:51 PM
Turbo6TA's Avatar
Turbo6TA
Sayfoo ...
You forgot to mention adding an STP sticker to the side of the catch can.
