Help Clutch pedal issues
Old Aug 11, 2023 | 11:34 PM
Connershupe's Avatar
Connershupe
6th Gear
Default Help Clutch pedal issues
Just installed a act twin disk clutch on my 2006 corvette. When I push the clutch in there is at least 2 inches of play at the top of the pedal. I didn’t shim the clutch. I used the clutch alignment tool and everything lined up. Just curious if I need to pull it back out and shim it or if my master slave cylinder is bad.
Old Aug 14, 2023 | 10:56 PM
Dano523's Avatar
Dano523
Number you want in the end, about .130" of the TB before it touches the pressure plate fingers, with the TB suport race take up spring compressed all the way back towards the base of the slave in the TT front face.
Old Aug 15, 2023 | 03:29 PM
Spaceme1117's Avatar
Spaceme1117
Take it back apart and measure. Shim if necessary. Hard lesson to learn but you need to do it right.
To Help Clutch pedal issues
