Another failed 2005 BCM
Ok you need to purchase from Dino. So the issue with my contact is he wants to deal with businesses and not individuals. If you knew how busy he was you would understand. So what I would suggest is send all the ones back to where you bought them that do not work. If you still have your original then send that to Dino and they can pull the original programming off of it and install it on a good working BCM.
I'm not even sure where to start on this because it is so long I could not keep up all the way through it. Yes a used BCM can be reprogrammed but it has to be done with the correct software and knowledge. Refer to what I said above and go through Dino's salvage for the BCM's. He is using my friend who does this but I can't give out his information, sorry.
Justin
Justin
Justin
Justin
My friend you are in the U.S. and while I am sure your friend knows what he is doing and is good at it this really is not practical or feasable for members of this forum who are in Canada or elsewhere. My post although long ( the first sentence warned of that ) was more to INFORM others of what will NOT work so that they are not spending countless hours and dollars trying what will not work. I know what works and what does not and there are a few up here that can do the same as your friend is doing. My post has been removed I am starting to notice a trend with people having a hard time with posts that are longer than 2 sentences not only mine but others as well.
Justin
Its not that it is a long post, it is that you kept saying the same thing over and over. Yes lots of Canadian owners on having these same issues. Shipping is not that much in the scheme of things to get fixed correctly though, you can buy several used BCM's and then pay the shipping vs having it fixed the first time. I hope you can get yours fixed but there is already someone in the U.S. that is successful in doing it so why wait around to see if someone locally to you can do it? Either way good luck to you and hope you get your issue figured out.
Justin
Justin
you missed something ...mine IS fixed, I wasnt the poster that bought several BCMs ...
"Ok you need to purchase from Dino. So the issue with my contact is he wants to deal with businesses and not individuals"
im willing to bet many of these bcm and other electrical failures could have been avoided buy not jump starting or attempting to start these cars with a dead or weak battery.........ive seen it many times only after it was done then having issues.
crowell (10-15-2023)
Not the only cause of failures but definitely a huge contributor.
