Lost Power
Old Sep 19, 2023 | 07:30 PM
gogsprostrt's Avatar
gogsprostrt
Default Lost power
It’s an oldie but goodie
Old Sep 19, 2023 | 07:46 PM
gogsprostrt
Default Lost power.
I disconnected the hvac control on the new head unit. The car fired up. I sure appreciate you taking the time to help me.
Old Sep 19, 2023 | 07:58 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I was just thinking about the HVAC module other than the radio…it’s connected somehow to your new head unit ??…which one did you buy ??
Old Sep 19, 2023 | 08:07 PM
gogsprostrt
Default Power loss
You can look up the unit, it’s a night Drive TV max XM. Replaces the head unit hvac and ash tray and heated seat controls
Old Sep 19, 2023 | 08:13 PM
C5 Diag's Avatar
C5 Diag
OHHHHHHH…. that explains it !!…I’m thinking it’s just the radio…maybe if this was mentioned I probably have told you to disconnect the HVAC wiring also…I’m not sure about the harness you’re using for the radio and HVAC so I couldn’t tell you much more…I’d like to see how this thing is wired…I bought the Kenwood DMX 908S…well it’s not your ignition switch so you’ll have an extra one.
Old Sep 19, 2023 | 08:25 PM
gogsprostrt
it’s a beautiful unit. Plug and play
Old Sep 19, 2023 | 08:27 PM
C5 Diag's Avatar
C5 Diag
So if you plug in the harness for the HVAC the problem comes back ??
Old Sep 19, 2023 | 08:30 PM
gogsprostrt
Default Lost power.
I can email you the instructions which is full of pictures. I’m
gogsprostrt@aol.com
Old Sep 19, 2023 | 08:36 PM
gogsprostrt
Default Lost power
I reconnected everything and voilà, all the issues came back. I disconnected the HVAC again, car is normal again.
Old Sep 19, 2023 | 08:38 PM
C5 Diag's Avatar
C5 Diag
If you didn’t do any rewiring for the install then I’d contact the manufacturer…it has to be how the serial data bus is wired by them if it’s all PNP…when you said you put all the wiring back to original I don’t know if that was just for the radio ??
Old Sep 19, 2023 | 08:42 PM
gogsprostrt
It’s all plugs. No cutting or splicing. I’m already reaching out. Thank you again.
Old Sep 19, 2023 | 08:44 PM
C5 Diag's Avatar
C5 Diag
No problem…something on that wiring is F’ed up !!
