Leaf spring mounting bracket threads
Old Sep 30, 2023 | 03:23 PM
Dreamer2's Avatar
Dreamer2
Default Leaf spring mounting bracket threads
Pulled the front leaf to facilitate oil pan removal. In the process, the leaf bracket to cradle bolt hole seems cross threaded. Must of happened by me incorrectly unbolting brackets under load. Going to bye a tap and die, chase the threads and hope for the best.
Old Oct 1, 2023 | 10:24 AM
sleepingcougar's Avatar
sleepingcougar
sorry to hear that and good luck to you.
if thread chaser and tap don't solve the problem, other option is helicoils.
Old Oct 1, 2023 | 06:27 PM
davidfarmer's Avatar
davidfarmer
the leaf spring is curved and under a lot of stress even lifted off of the ground. I don't use the GM tool, but you really need to compress the spring to remove the bolts without damage
I'd buy a new cradle and swap it if necessary. I have a collection of them, especially
Old Oct 3, 2023 | 06:40 AM
Spaceme1117's Avatar
Spaceme1117
Heli-coil.
Old Oct 3, 2023 | 02:43 PM
Rokket's Avatar
Rokket
A couple of mine stripped out. I used Time-serts to fix them.
To Leaf spring mounting bracket threads
