Upgrading for winter. Am I missing anything?
Old Dec 25, 2023 | 11:29 PM
schizcat's Avatar
schizcat
Originally Posted by Slick Nick
No you’re not and I’m wrong for assuming the case came with the new differential. I’ll call them Tuesday to get new case. Thanks!
i don't think that RPM will even give back an 05 diff. they will just upgrade to an 06 or newer.
Old Feb 20, 2024 | 10:20 AM
m60gov20's Avatar
m60gov20
I'm having the RPM stage 3 differential installed 3.73 gear ratio.
Don't do the gears. You won't want them with a PD blower. I did .3.73's in mine when I was on low boost and have since went back to 3.42's in a zr1 housing. With ported blower (Ironmask Airflow) SBE ls3 and a bigger cam then your doing I made over 750 lbs of torque by 2,700 rpm. If you're going to put some tires on it and take it to the track I'd do the ZR1 housing especially if you're changing housings anyways. You might look into a clutch tamer also.
Old Feb 20, 2024 | 01:05 PM
Slick Nick's Avatar
Slick Nick
RPM reached out and strongly advised against 3.73 gears so I went with their recommendation and got the 3.42. This will mainly be a street car.
