Marvels Mystery Oil
Old 12-20-2023, 06:24 PM
Grizzi
Grizzi's Avatar
Default Marvels Mystery Oil
Has anyone actually ever used Marvels? I’ve been told by some older gentleman that I should add some to help clean out the gunk and stuff from my engine but idk if I should believe him or not… so can anyone say he has a point or don’t even bother trying it. If so should I add some then do the oil change after a certain time?
Old 12-20-2023, 09:44 PM
old motorhead
old motorhead's Avatar
Received 1,349 Likes on 955 Posts
I used to use it in my airplane at every oil change. That was quite a few years ago. Also, the Lycoming engine was air cooled and ran straight 50wt dino oil. With today's oil's, I see no reason to use it. Every engine I've opened up in the last 20 years had absolutely no deposits. You couldn't tell them from a brand new engine. If you've changed your oil on any type of regular basis, you should be fine.
Also, I'm not even sure that MMO will play nice with current synthetic oils. They may have changed the formulation.
Grizzi (12-20-2023)
Old 12-21-2023, 03:26 AM
Dano523
Dano523's Avatar
Received 3,052 Likes on 2,194 Posts
Ditto, was good when using the old Dino oils, since they would crude and some even had paraffin wax that would cause baked on deposits, and such help to slowly deresolve them away that the detergent in the oil may have not instead.
With the current synthinc oils, and doing oil changes as needed, you don't end up with the above deposits in the first place.
Hence about the only place that I would suggest that somoene used marvel oil in a C6, was if someone was not doing oil changes as required on the motor, and say had a lot of build up in the lifters that needed to be cleaned out quicker then the synthetic oil would do on its own.
Grizzi (12-22-2023)
Old 12-21-2023, 09:32 AM
Spaceme1117
Spaceme1117's Avatar
Received 1,321 Likes on 892 Posts
Its a good additive to add to your gas as it can help to keep the fuel system in good condition and lubricated. But it's not necessary.
If you are going to change your oil and wanted to "clean" the internals of the engine, I would use LiquiMoly Pro-Line Engine Flush. You add it right before an oil change. You add it to the oil, bring the engine up to temp, and let the car idle for about 15 minutes. Then do the oil change.
Grizzi (12-22-2023)
Old 12-21-2023, 10:24 AM
wmupaprmkr
Cool Hand Luke of W MI
Support Corvetteforum!
wmupaprmkr's Avatar
I've used MMO in my high mileage daily driver to quiet a lifter tick. I added one quart of it when I did the oil change and it did the trick.
Not sure I would use it on the C6.
Grizzi (12-22-2023)
Old 12-21-2023, 04:23 PM
65 Drivr
65 Drivr's Avatar
I used to use it on my cars back in the day. A few ounces in the gas and a 1/2 qt in the oil. As others said I don't think it's needed anymore.
The following 2 users liked this post by 65 Drivr:
Grizzi (12-22-2023), LightningBrett (12-21-2023)
Old 12-22-2023, 01:14 AM
wjnjr
wjnjr's Avatar
Grizzi (12-22-2023)
Old 12-22-2023, 10:07 AM
grinder11
grinder11's Avatar
Received 3,605 Likes on 2,556 Posts
Probably not a good idea to add to gas with cats, unless you add a small amount, like maybe 4oz. to a fillup. I added 4oz. to a fillup, and about 8oz. to the sump. I've used it twice in the last 2 years. I suppose it could also cause issues with O2 sensors, if used in gas in larger quantities....
Grizzi (12-22-2023)
Old 12-22-2023, 01:06 PM
Grizzi
Grizzi's Avatar
I’ll probably add some to the gas tank just because I do feel like that does need a cleaning and I’ll definitely look into that liquiMoly pro line to help with anything else, thank you for this tip!!!
Old 12-25-2023, 05:15 AM
sirdano
sirdano's Avatar
only put tectron in the gas and mobil one in the oil nothing else
Grizzi (01-10-2024)
Old 12-25-2023, 08:05 AM
BadAV
BadAV's Avatar
Received 2,710 Likes on 1,720 Posts
Old 12-25-2023, 11:56 PM
I30
I30's Avatar
Marvel is transmission oil, why it has good cleaning qualities.
Old 01-10-2024, 09:36 PM
bwill03z
bwill03z's Avatar
Marvel - no “s” lol sorry it bothers me, kinda like when ppl spell Mobil1 as Mobile…
anyway I’ve always heard good things about it. I have used it several times on a couple different cars, pouring it into the crankcase prior to an oil change. Unless your motor is gummed up or have alot of carbon build up I don’t think there’s really any benefit to using it.
Grizzi (01-10-2024)
Old 01-21-2024, 08:21 AM
yeller z06
yeller z06's Avatar
You can buy Marvel at the K-marts.
LOL, I always thought it was a Southern thing, to make everything plural.
Grizzi (01-21-2024)
To Marvels Mystery Oil
Quick Reply: Marvels Mystery Oil
