Fuel Pumps at Bottom of Tanks on 2006 and 2007?
This recent video from C&S Corvettes claims that the positioning of the fuel pumps on 2006 and most 2007 Corvettes is different from 2008 and newer. Specifically, Lyle states that the early pumps mount at the bottom of the tank, while the newer pumps mount at the top of the tanks. Furthermore, he states that the early pumps have a metal top plate, while the newer pumps have a plastic top plate. Is it true that the mounting positions and top plate material is different between early and late? And if that is true, does that mean 2006 and most 2007 don't commonly have the fuel smell problem? Note: Although 2005 isn't mentioned in the video, I would assume it is included with 2006 and 2007.
https://www.youtube.com/watch?v=TEQwziWCigQ&t=1s
All C6s have plastic top-mount pumps. The fuel system design switched from bottom-mount pumps to top-mount pumps late in the C5 run.
He must be confusing the pump position change and the level sender resistance change. The level sender resistance range was changed in 2007.
ClothSeats (01-17-2024)
The chronology presented in the video is completely screwed up.
In 2007 or so the fuel level sensor resistance did a reversal. The old way was 0 empty 240 ohms full in 2007 it went to 240 empty to zero ohms full. The logic there was as the pump aged the ohms resistance got worse. So a zero normally might be say a 30 ohm after 100K miles so you thought you had gas in the tank and you did not. When ordering a new pump for the older car you need to be aware of what gauge you have or swap you level gauge in tank out to new pump.
Spaceme1117 (01-19-2024)
C6VetteLover (01-31-2024)
