Engine codes
Old May 22, 2024 | 09:35 PM
Noob_z06's Avatar
Noob_z06
Cruising
Default Engine codes
So I ran a scan tool for a check engine light on my 07 z06 and I got back a P0208 injector 8 control and a
P0106: Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem what could be the fixes for these 2 codes
Old May 22, 2024 | 09:54 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you have a 12 volt test light and DVOM to check the injector for the P0208 ??…what do you see with your scan tool looking at MAP Sensor and Baro data PIDS with ignition ON either in inches Mercury or voltage ??…0208 could be injector, wiring, or bad ECM.
Old May 22, 2024 | 10:29 PM
Noob_z06's Avatar
Noob_z06
Cruising
Default Injector code
so I found the problem with the injector code um the the injector wasn’t plugged in lol but what about the map code?
Old May 22, 2024 | 10:35 PM
C5 Diag's Avatar
C5 Diag
As I mentioned what does BARO and MAP sensor read with ignition on ??…are you at sea level ??...engine off ignition on you should see around 101 KPa or 29.8 on BARO...MAP voltage should be around 3.96 volts or so...just want to make sure your MAP reading isn't skewed...finding the injector not plugged in were you doing any recent maintenance ???...injector connector just doesn't fall off.
To Engine codes
