C6 LS3 o2 sensor
Old May 25, 2024 | 04:28 PM
Ed1801's Avatar
Ed1801
Default C6 LS3 o2 sensor
A rotten egg smell coming from exhaust at high speeds, can it be a bad o2 sensor ? Not getting any codes. Also, car feels sluggish at low speed. This is a 08 ls3 A6
Old May 25, 2024 | 04:32 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With a loss of power and rotten egg smell sounds like a possible bad cat…possibly clogged.
Old May 25, 2024 | 04:36 PM
Ed1801's Avatar
Ed1801
Car passed smog check recently. Wouldn’t it had failed with a bad Cat?
Old May 25, 2024 | 04:41 PM
C5 Diag's Avatar
C5 Diag
With your concern I imagine it would have failed your smog check.
Old May 25, 2024 | 06:26 PM
PMPerformance's Avatar
PMPerformance
With no code, but a sudden slight power loss, I'd venture to guess a cat is starting to clog up. Not enough to throw a code yet, but enough to cause performance issues. When I had a bad cat, it would come after driving for a bit and under load like going up hill, the car would fall flat on its face until I let it cool down again.
To C6 LS3 o2 sensor
