starter heat shield
Old Aug 26, 2024 | 12:29 PM
slowtealz28's Avatar
slowtealz28
Default starter heat shield
What are you guys using? After a couple years of having longtubes in south florida my starter went. The shop that does my maintenance said I should throw one of these on there, what are you guys using? Found this one
Amazon Amazon
Old Aug 30, 2024 | 10:25 AM
kcjeepguy's Avatar
kcjeepguy
I had the same issue on my 2012 C6 Z06 with American Racing un-coated long tube headers. The starter heat shield made by Lingenfelter, while expensive, has served me well. https://www.lingenfelter.com/product/L800010000.html
Edit: I looked at that amazon link, and all I will say is my previous starter had a heat wrap/tape on it and it died. I think those tend to trap heat rather than act as a shield.
Last edited by kcjeepguy; Aug 30, 2024 at 10:27 AM. Reason: Adding information to the post
Old Aug 31, 2024 | 08:48 PM
hubes's Avatar
hubes
https://www.corvetteforum.com/forums...at-shield.html
Old Sep 1, 2024 | 11:40 AM
rsb213's Avatar
rsb213
i’ve gone through like 5 starters. including after doing the heat shield wrap. now i run both of the shields in the previous 2 posts and my problems are gone.
Old Sep 2, 2024 | 07:07 PM
slowtealz28
Thanks for this. I figured I will go through them pretty quick so I did a remanned starter with a “lifetime warranty”. We’ll see about that, only request from the shop owner was that I got a heat shield for it.
Old Sep 5, 2024 | 08:22 AM
WasVette's Avatar
WasVette
ditto this; ever since installing the Lingenfelter shield, adding an additional zero gauge ground from the battery to the frame in the rear and cleaning block to frame ground in the front. I have not had a single heat soak no start experience.🙏🏻👍
To starter heat shield
