Hi, my engine light is going on after I drive my C6 2013 ZR! for a few miles. The car only has 2100 actual miles. I have tried disconnecting the battery terminal and then re-connecting it. That works for a few miles, then the light comes back on. Any suggestions
Yes, get the code or codes read and let us know what you have...as a new member it's a good idea to fill in your profile with as much info as you can...more than you live in the US and you're a male.
When a car's CEL is on, the thing to do is read what diagnostic codes it has registered. For that you need a code reader. Autozone or most other auto parts stores will read the codes for you for free.
Only then will you be able to have an idea of what the problem is. And then you can go about figuring out how to fix the problem.
I'll go out on a limb and say a 13 with 2100 miles needs a good fuel system cleaner and a good long highway rub. Change the oil and filter than warm it up by driving normally then drive it like you stole it.
