Question about engine swap.
Old Feb 9, 2025 | 05:32 PM
Tx_Mike72's Avatar
Tx_Mike72
1st Gear
Default Question about engine swap.
I am looking at a C6 that does not have motor or trans. Very nice car overall.
I built a 6.2 from an 07 Denali for a different project, then changed my mind. Can I use the ecm/bcm/tcm from this C6 and put my 6.2 in the car? I know I would need it tuned, just need to know if I need a new ecm or not.
Thanks in advance.
Mike
I got the info needed. 👍
Old Feb 10, 2025 | 05:36 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Thanks in advance.
Mike
Yep, shouldn't be an issue at all. If its an iron block some sensors may be located a little differently but all stuff thats easy to fix. If its an aluminum it should pretty much be plug and play (tune withstanding). You'll need a Corvette front drive assembly and balancer though, truck stuff sets out way too far.
