Would stereo install trigger P0171 code?
Old Feb 28, 2025 | 06:44 PM
Concrete Mike's Avatar
Concrete Mike
5th Gear
Default Would stereo install trigger P0171 code?
I’ve owned my ‘13 Grand Sport for four months. It has ran flawlessly with no engine codes. So, I just had a new stereo installed by Best Buy and I come back to pick it up and the check engine light is on throwing a P0171 code. Is there a chance they could have triggered that code doing the install? Or is just a coincidence?
Old Feb 28, 2025 | 07:01 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Just a coincidence…any recent work done on your car ??…if you can look at your fuel trims you can see if you may have a vacuum leak on bank 1 (left bank)…you can look at “freeze frame” data on your scan tool and see if the RPM was near idle…if code occurred at idle most likely a vacuum leak.
Old Feb 28, 2025 | 07:16 PM
Concrete Mike
5th Gear
Thanks for your input! I put a Corsa cold air intake on about 800 miles ago, but that’s the only thing I have done to it. I personally do not have a scan tool, the Best Buy installer showed me what the code was. What’s a good scan tool reasonably priced in your opinion?
Old Feb 28, 2025 | 07:30 PM
C5 Diag's Avatar
C5 Diag
An aftermarket air intake would cause a P0171 and P0174 for both banks depending on the manufacturer…your bank 2 fuel trims are most likely just below the percentage that will trigger that code…you don’t want to get a cheap “code reader” as they are useless for other than just reading and erasing trouble codes…you want a scan tool that can read all trouble codes other than just Powertrain codes which a code reader will only do…this Autel will read all those and is bidirectional which you can command “outputs” such as turning on a cooling fan or fuel pump and also look at inputs which you can see if you push a door button you can see if a computer can see that input.
Old Feb 28, 2025 | 07:34 PM
Concrete Mike
5th Gear
Thank you for all the information!
Old Feb 28, 2025 | 07:40 PM
C5 Diag's Avatar
C5 Diag
No problem !!
Old Mar 4, 2025 | 09:59 AM
woodsdesign's Avatar
woodsdesign
goods info, thanks for posting.
To Would stereo install trigger P0171 code?
