Stuck
Plug
Wire
Coil Pack
Coil Pack wiring
Fuel Injector
Fuel Injector wiring
Fuel Injector wiring- bad ECM/PCM
Valve Spring broken
Burned Valve
Cam Lobe worn
Low Compression- Rings
Most people, and maybe most 'mechanics' think the only job skill required of us is the ability to change parts.
It takes time to develop skills in diagnosis, and requires quite a bit of knowledge. Talented technicians don't grow on trees.
Maybe the hardest part of DIY auto repair is knowing when to say 'when'; recognizing that you're in over your head.
DIY is great, and I encouraged all my customers to participate, but only to the point where they were confident of success.
Asking for diagnostic advice without some basic skills in that area will lead you to replace a lot of perfectly good parts.
Like alternators....
Be careful accepting advice if your skill level isn't adequate to properly ascertain its worth!
Good luck with the misfire.
Broken or weak valve spring was my first thought, but there's no substitute for a systematic diagnostic approach.
One of my favorite sayings..."All mechanics are not diagnosticians, but all diagnosticians are mechanics" !!
On a pontiac 400 engine the sold me the wrong timing chain set. That car too was limited to 2500 rpm. We are only guessing since we dont have all the details that went into previous fix. Like parts list on what was replaces, work done etc
