C6 handling vs C5
my uncle bought a 2001 base model C5 this past weekend and I got a chance to drive it yesterday and I was pretty surprised at how the car felt more planted to the road and the steering felt quite a bit heavier than in my car. As far as I can tell all the steering and suspension components are bone stock in this car. It is a low mileage car but still I did not expect it to feel considerably better than my car as far as handling. I wish there was a way to make the steering feel a little heavier in these cars. Other than tires I guess really the only thing I could do without replacing any suspension components is go with a little bit more aggressive alignment. Anyone else have a similar experience in comparing a C5 to a C6 in handling/steering?
If you jump up into C6 GS or Z06, then light years better in handling/track needed options over the older gen C5Z06, which has been the same for every gen upgrades if talking same model to model, like Z06 to Z06.
Simply put, every gen upgrade of the vet, has it handling better/sharper, but in the grand scheme of sports car, lets just say lacking behind the field of import cars, so still showing up to the opera, in pair of assless chaps.
Simply put, every gen upgrade of the vet, has it handling better/sharper, but in the grand scheme of sports car, lets just lacking behind the field of import cars, so still showing up to the opera, in pair of assless chaps.
DanO wrote: "Simply put, every gen upgrade of the vet, has it handling better/sharper, but in the grand scheme of sports car, lets just lacking behind the field of import cars, so still showing up to the opera, in pair of assless chaps."
Great line Dan!Hence power steering is great for parking lot maneuver, but on track, will agree with you that the steering can feel too light on the C6 and you do lose some road feed back through the well due to such.
The second one that is missed a great deal of the time, is the steering rack can be adjusted/heaver spring installed, and should as wear causes more slop in them.
Good crash course on the steering racks, including the yoke rod adjuster.
https://www.corvetteforum.com/forums...n-rebuild.html
The last one, change out the FE1 front trans spring to FE3 that comes stock on the Z51(make sure to get correct one for which trans is in the car) then double check the ride height of the car/change out the ride height to Z51 height specs during corner balancing.
The base cars come with FE1 springs, are too weak up front, and where you losing a lot of that front end feel in the corner as well.
To short bus it, the base cars came pretty much old man cruising/soccer mom specials with light supensions, the Z51/GS was upgraded for Autocross use, while the Z06, all the way up to the C6, was designed for more brutal high speed use road car from the start.
And why I state up to the C6, the C7 Z06 had over heat problems on track, and instead of GM resolving the problem, just changed their whole tune, with none of the cars being high speed road course built from that point forward.
And if you want to play blind fold test between C5 Z06, and the C6 z06 when both are set up correctly, its night and day in the back end, of which will cut a cleaner corner under power on the way out.
You mentioned changing out the front spring should I not change the rear spring out to the Z51 spring also?
The couple of times I drove a C5, I thought the turn-in on track was AMAZING, whereas I find the C6 is more prone to push into corners .......... due to the shorter wheelbase of a C5, I think it helps improve cornering capability (at least for tight corners), more akin to a Porsche (which have an even shorter wheelbase than a C5).
Now, how does that translate into a heavier steering feel?? I don't know. But I do think that comparing a C5 to a C6 isn't 100% apples-to-apples.
The other thing to consider would be tire WIDTH ............... just the difference between my former base C6 and my C6Z, the front tires go from 245's to 275's, and that alone adds some heavier feel to the steering, so depending on what you were used to, that could be a factor as well?
It's been A LONG time ago since I sold my 98 (traded in on a 01 Explorer XLT) so 1/4 of a century. But as it was the base FE1 suspension car (had about 22k miles) memory says that it's handling was a wallowing boat! (my next car I bought was an 02 Honda S2000 in late 2002) I'd compare the 07 Convertible with Z51 in my garage to the S2000 in handing.
https://search.brave.com/search?q=c6...b1b8c5f099bc63
I think the C5 did have slightly better handling than my GS but not by much. I think it is likely due to the GS being a few hundred pounds heavier than the C5.
But the GS does have similar suspension upgrades as the C6 Z06 plus the wider wheels which are significant upgrades vs a base C6.
I also found that the C5 Z06 was less refined in both the steering and handling than the C6. So I definitely felt more connected to the road than in my C6.
So overall, I think your impressions are correct in regards to the C5 versus the C6. C5 was less refined so gives a more connected and visceral feel when driving. C6 insulates the driver more from the road and so is a more comfortable cruiser.
C5 Z06 is a true drivers car and there are times that I miss mine.
My story, both Verts & Z51 w/ runflats, my C5 had Bilsteins, chassis stiffeners both upper and lower, adjusted brake bias, slightly lowered, etc and my recollection of thoughts (20 years ago - oh my) was my stock C6 out handled it with better corner handling.
My C6 now has the tunnel plate stiffener, is slightly lowered, all the bushings are in good condition, and an altered alignment to reduce front tire outer edge wear.
It handles and feels roadworthy, fun, with longer tire life.
Yes, tires may be the biggest variable, plus any aged suspension.
Fresh power steering fluid I would recommend.
Yet, steering tension/ feel was never an issue for me in either Vert.
Yes, there are betterments to the OEM alignment specs and even a need to verify ride height.
Lastly, finding the proper tire pressure with a pyrometer could also be a benefit to your C6.
OP, have fun
