Harmonic balancer
Old May 9, 2025 | 10:43 PM
quiet.c6z's Avatar
quiet.c6z
4th Gear
Default Harmonic balancer
Hello do you guys think my harmonic balancer is going out and causing this whistle chirping noise
File Type: mov
Old May 11, 2025 | 07:11 PM
crusher1's Avatar
crusher1
Cant really see anything. Need to take a video from the passenger right side
Old May 12, 2025 | 06:17 AM
Hutchy's Avatar
Hutchy
Take from passenger side and hold your camera very still. Sounds like a belt squeek to me, but could be harmonic balancer.
Old May 12, 2025 | 01:39 PM
Kbomb's Avatar
Kbomb
5th Gear
Default Replaced
I had mine replaced, had a slight wobble. The shop that did mine threaded and used a bolt. Said they change about 3 a month.
Old May 13, 2025 | 10:50 AM
zmetro's Avatar
zmetro
LS2 1SB Cobalt Red
I had a bad harmonic balancer on my 05, you can visibly see the wobble, and I had a slight consistent chirp as shown in the clip (my video attached below), as you can visually see the belt getting closer and further away from the edges of pulleys and the wobble, if the balancer looks like its visually wobbly replace it but from the video you sent you are moving too much to visually see, go to the passenger side and hold the video very still, or a dealership has a laser device that can check all of your pulleys are aligned
Old May 15, 2025 | 02:11 PM
Jetstream Blue Bill's Avatar
Jetstream Blue Bill
Thats the most solid looking harmonic balancer on a LS motor I've ever seen. I'd relieve the pressure on the serpentine belt and check the idler pulley for free spinning without squeaks. If my harmonic balancer looked that good, I'd quit looking at it.
Old May 15, 2025 | 02:35 PM
quiet.c6z's Avatar
quiet.c6z
4th Gear
I just got the car back from the shop and I had them do a diagnostic on all of the belts and pulleys and they said that everything looked good and the the chirping was from moisture on the belt.
Old May 16, 2025 | 05:23 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Looks fine. Try some belt dressing.... https://www.autozone.com/greases-and...B&gclsrc=aw.ds
To Harmonic balancer
