Transmission fluid additive recommendation
Old Jul 7, 2025 | 03:35 PM
Mackee's Avatar
Mackee
Default Transmission fluid additive recommendation
C6 colleagues, my 2008 Automatic C6 has a harsh shift from 2nd to 3rd gear when push hard. Found out that there is a Service Bulletin stating that this is caused by some seals leaking.
I also found out that this is a common problem on the 6 speed transmission 6L80 used on many GM vehicles including Corvettes from 2006 to 2012. I suspect many of you having the same issue, I would like to know if you have used any transmission additive to condition the seals and which one is the most effective.!
Thanks in advance for sharing your wisdom!
Old Jul 14, 2025 | 08:50 AM
wagsk's Avatar
wagsk
6th Gear
additive just swells the seals does not really "condition" them. Is it an external leak in the SB?
