Dry Start
Old Jul 13, 2025 | 04:01 PM
DESI6327's Avatar
DESI6327
Default Dry Start
My C6 GS has been sitting since December ‘24. I’ll be starting her soon. Gas has been treated & she’s on a trickle charge, oil & coolant are good. Is the method of: Depressing throttle to floor
Clutch in
Hitting “Start” for 5-7 seconds 4 or 5 times, the best way to go? She’s a convert, so no dry sump
This is my first later model. I’m basically a C1, 2 & 3 guy.
TIA
Old Jul 13, 2025 | 04:11 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes.
Old Jul 13, 2025 | 05:20 PM
Rebob0510's Avatar
Rebob0510
That method works great, Just hold it wide open... Hit the start button and will crank. If you want you can continue to hold the throttle until it times out and it will stop cranking. I think it will do that after 10-15 seconds. Then you can start it again like normal or even give it another round to endure you are getting the oil moving around
Old Jul 13, 2025 | 10:09 PM
DESI6327's Avatar
DESI6327
Thank you!
Old Jul 13, 2025 | 10:33 PM
DESI6327's Avatar
DESI6327
Originally Posted by C5 Diag
Yes.
Thank you
To Dry Start
