Bulb out detection
Old Oct 22, 2025 | 07:08 PM
cadbob's Avatar
cadbob
Default Bulb out detection
Can the bulb out detection be turned off with the Tech2?
if so where in menu would I find it?
    • disable bulb-out detection for turn signal
Old Oct 22, 2025 | 08:07 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
“Bulb out detection” with the Tech 2 ??…never heard of that…what are you trying to do ??
Old Oct 22, 2025 | 08:11 PM
cadbob's Avatar
cadbob
Trying to get rid of some resistors here is my thread there is 3 threads on subject thou. But this might explain.
https://www.corvetteforum.com/forums...sh-solved.html
Old Oct 22, 2025 | 08:14 PM
C5 Diag's Avatar
C5 Diag
Can’t help you with that aftermarket stuff…nothing in the Tech 2 for whatever you’re trying to do with these resistors.
Old Oct 23, 2025 | 05:11 AM
cadbob's Avatar
cadbob
Yes I read that it's not a option as it's coded into the BCM.
To Bulb out detection
