Check engine light
Old Nov 11, 2025 | 09:53 PM
Blast_off440's Avatar
Blast_off440
Default Check engine light
2009 c6 z06 427 check engine light came on, everything seems fine, what's the best way to go about having it looked at?
Suggestions on what kind, code reader, make and model would be welcomed.
Thank you for the replies.
Last edited by Blast_off440; Nov 13, 2025 at 07:09 PM. Reason: Code reader was the top suggestion, curious what kind is best for my situation.
Old Nov 12, 2025 | 08:45 AM
cthusker's Avatar
cthusker
Codes, codes, codes.... First thing you pull imo!
Old Nov 12, 2025 | 11:16 AM
Landru's Avatar
Landru
^ +1
No code reader?
Fine.
Most ANY parts store reads codes for free.
Learn WTH your Z's trying to tell you.
Old Nov 12, 2025 | 02:42 PM
fat biker's Avatar
fat biker
Code Readers are not a huge capital outlay.
IMO, Every Modern Gearhead Needs One!
Old Nov 13, 2025 | 07:10 PM
Blast_off440
Any suggestions on what brand/model?
Old Nov 13, 2025 | 07:11 PM
Blast_off440
Thank you.
Old Nov 13, 2025 | 07:13 PM
Blast_off440
No code reader, what kind should I get?
Just got the car @ 6 days ago.
Old Nov 13, 2025 | 08:25 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Code readers are worthless IMO…they only read “P” or Powertrain codes…a scan tool below can read trouble codes from all modules.
Old Nov 13, 2025 | 10:47 PM
Blast_off440
Thanks a lot.
Old Nov 17, 2025 | 08:10 AM
C6ToGo's Avatar
C6ToGo
You can get a simple code reader for 7 bucks on Amazon to avoid trip to parts store. Better to invest a min of 100 bucks for a fuller feature scan tool. I Use Tech2 but my Autel AL619 works well. Look for one with, at least, these features......CAN, ABS, SRS/AIRBAG, LIVE DATA
Old Nov 17, 2025 | 08:59 PM
Blast_off440
Thank you.
To Check engine light
