2005 C6 Throws code u1000, u1017 and u1040
Old Dec 8, 2025 | 02:13 PM
Corvettemac's Avatar
Corvettemac
Default 2005 C6 Throws code u1000, u1017 and u1040
Any advice on shops in so fla that might be able to help tried new battery after disconnecting , to no avail .
Car ran before we did engine swap . Now it wont even turn on , Wont start . I do get the key to recognize but nothing else .
Old Dec 8, 2025 | 05:27 PM
Aardwolf's Avatar
Aardwolf
Check the big plug in connections on fuse box and then BCM
Old Dec 8, 2025 | 05:51 PM
Rick Raffy's Avatar
Rick Raffy
Those are all data communication codes U1000 tells you there is a problem with data communication, U1017 is communication with the ECM, U1040 tells you there is a problem with the EBCM check wires going to ABS unit and engine module. If you have a wiring diagram you could see the colors of the data line. Check grounds for those modules also.
Old Dec 8, 2025 | 08:32 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What part of South Florida are you in ??…VERY few shops have the knowledge to diagnose communication issues.
Old Dec 8, 2025 | 08:51 PM
C5 Diag's Avatar
C5 Diag
CAN bus information goes from terminals 6 and 14 at the DLC in and then through and out of each module…if the EBCM connector is not fully seated you will not have comm to it and then downstream to the ECM.
Old Dec 8, 2025 | 09:07 PM
Corvettemac
im in west palm beach fl . Was on the phone with chuck from COW ( now south florida corvettes ) he was very helpful . Guy really knows his stuff .
I made a tiny amount of progress tonight , I am now getting the gauges to sweep and zero back . Still cant get the car to go into neutral . When I hit the ignition button and or attempt to start it , still nothing , but im still working on checking grounds at this point .
Old Dec 8, 2025 | 09:13 PM
Corvettemac
thank you !!! Definitely is a can bus ( ecm to bcm comms issue ) remote fob wont unlock my doors , but will recognize my name when slotting the fob into the glovebox. Guys at the shop put a lingenfelter box in it ( has a new 416 in it ) with a different reluctor wheel .
One of the grounds ( p side ) is on the number 8 header bolt . Chuck told me to look for stuff like this , Im assuming that ground should be on the back of the head not the header bolt , see photo .
Old Dec 8, 2025 | 09:14 PM
C5 Diag's Avatar
C5 Diag
You have to check more than just grounds to diagnose this…the only shop I know of in your area of is Assured Auto in Melbourne who can definitely diagnose it.
Old Dec 8, 2025 | 09:16 PM
C5 Diag's Avatar
C5 Diag
There is no ground that should be attached to the header bolt…see where it goes to…if a shop did the swap let THEM figure it out !!…if you disconnect the battery and check resistance between terminals 6 and 14 at the DLC it should read 60 ohms and not 120…there are 2 each 120 ohm terminating resistors in parallel one at the BCM and the other at the ECM.
Old Dec 9, 2025 | 05:57 PM
Corvettemac
im working on it , returning the car to the shop is not an option. That bolt has an eyelet that is too small for the bolt opening at the back of the head . I just tried it . I have to find out where the other end goes to .
Old Dec 9, 2025 | 06:19 PM
C5 Diag's Avatar
C5 Diag
There is no ground on the back of the block…G107 on the Drivers side is the ground for the coil packs and is the only ground that high up on the block.
Old Dec 9, 2025 | 06:33 PM
Corvettemac
This one is on the back side ( at least the eyelet ) is near the back of the p side head , wire looks to be around possibly 10 gauge , black and has a silver protectiv e sheath near the base where it goes into the loom
Old Dec 9, 2025 | 06:39 PM
C5 Diag's Avatar
C5 Diag
These are all the engine compartment grounds.
Old Dec 9, 2025 | 06:52 PM
Corvettemac
Its looking like g106 engine block ground , but its in the wrong spot . Probably causing the bad ground , will look at it again later . Sent you a dm . Thank you !!!
Old Dec 9, 2025 | 06:55 PM
C5 Diag's Avatar
C5 Diag
G106 and its location shown below.
Old Dec 9, 2025 | 08:24 PM
Corvettemac
Do u remember its relative location on the engine ? Back of block p side or on the side of the block just below the number 6 cylinder .
Old Dec 9, 2025 | 08:28 PM
C5 Diag's Avatar
C5 Diag
No I do not.
Old Dec 10, 2025 | 04:59 PM
1Hotrodz's Avatar
1Hotrodz
Sum Ting Wong
To 2005 C6 Throws code u1000, u1017 and u1040
