It would have the most recent file from GM installed. You might need to do a security relearn and perhaps a Crankshaft variation relearn with your scan tool once it is installed. Most higher end scan tools will be able to accomplish this.
This way you can have the car running with a stock "up to date" valid tune and a good known ECM before taking it to the tuner for dyno pulls and recalibration. Do a search on E Bay for 12597121. Look for one sold by FlashMaster (approximately $150 shipped). Have your VIN number written down. They have been around for a good few years.
It would have the most recent file from GM installed. You might need to do a security relearn and perhaps a Crank relearn with your scan tool once it is installed. Most higher end scan tools will be able to accomplish this.
This way you can have the car running with a stock valid tune and a good known ECM before taking it to the tuner for dyne pulls and recalibration.
thanks for all your help received my new ecm, plugged it in and everything worked fans kick on a it should no more codes.
