Ceramic Front Pads w/ OEM Rear a Problem?
Old Dec 24, 2004 | 02:37 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Ceramic Front Pads w/ OEM Rear a Problem?
What are your thoughts of installing Ceramic Pads, for dust reduction, on the front and leaving the OEM pads on the rear? Will that create handling problems? I’m not an aggressive driver. Thanks in advance.
Old Dec 24, 2004 | 03:29 PM
jschindler's Avatar
jschindler
I've done that on two cars (non Corvettes) with no problems. I would not hesistate to try it.
Old Dec 24, 2004 | 04:28 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
keep us posted!
Rain
Old Dec 26, 2004 | 09:16 AM
AU N EGL's Avatar
AU N EGL
Ceramic pads are fine for street use and normal braking conditions. I would change all four wheels.
In an emergancy situation your may experience greater rear brake bias, or more stopping ability on the rear wheels then on the front. Normally the front brakes do the most work for stopping.
Straight line stopping is the ideal situaltion, however, ideal almost never happens. when brake bias is not in the proper preportions the car may weave uncontolabley. To much front brake bias may cause the rear of the car to swing around. To much rear brake bias my flat spot rear tires, or with ABS put three flat spots on rear tires. and or cause the front of the car to swing from one side to another.
Brakes are designed as a whole system, not piece meal. Brake pads are also designed as a whole system, front and rears to work together.
Old Dec 27, 2004 | 11:41 AM
carpe dm's Avatar
carpe dm
Old Dec 27, 2004 | 03:37 PM
HalM's Avatar
HalM
Correction....too much rear bias will cause the rear to spin around...too much front bias just overloads the front...the race car is adjustable front to rear...I get to run this experiment all the time...
JFT: Your average street driver will be fine with what you propose...even in an emergency...the C6 has so much electronics monitoring the braking the worst thing that will happen to you is some loss of efficiency...
Old Dec 27, 2004 | 03:42 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Thanks
Thanks for the input folks. Y'all are making me more dangerous with my limited knowledge every day. Appreciate it.
Old Dec 30, 2004 | 06:00 PM
cuspid's Avatar
cuspid
The GTO guys are putting C5 ceramic brakes on the front and are leaving the GTO rears on. The C5 fronts are double the size of the GTO's fronts. I have read posts that some of the z06 guys are putting ceramic on the front and are leaving factory rears. Who knows the answer?
Old Dec 31, 2004 | 07:35 AM
BriJac's Avatar
BriJac
Default Jft
Let us know if you make the change and who you go with, price, difficulty, etc.
Old Dec 31, 2004 | 09:25 AM
cuspid's Avatar
cuspid
Some of the c5 z06 guys are switching to the front ceramic only.
Old Dec 31, 2004 | 12:40 PM
jimman's Avatar
jimman
You could run some skid pad test I guess, but wait GM has done that, why tempt fate
Old Dec 31, 2004 | 01:31 PM
AU N EGL's Avatar
AU N EGL
Ceramics are for dust reduction not better stopping. may have 5% less stopping ability with ceramics. That is ok for normal street driving. so there is a trade off.
When the carbon-ceramic pads have great stopping but are very dusty too.
I prefer the dust and better stopping abilty and just wash the car and wheels more.
Old Dec 31, 2004 | 02:02 PM
Boozman's Avatar
Boozman
Old Dec 31, 2004 | 02:31 PM
RainJ's Avatar
RainJ
When the time comes, Ceramics go on my front
Rain
To Ceramic Front Pads w/ OEM Rear a Problem?
