C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Welp, pulled the trigger
Old Dec 3, 2018 | 08:04 PM
samwint77's Avatar
samwint77
Default Welp, pulled the trigger
I just ordered the maggy heartbeat with the 3" pulley, texas speedway headers and x pipe. I have a local shop installing it when everything comes in. I have a 2017 grand sport. I can't wait to get this thing going. I'll post dyno numbers when its complete. I decided to go with the PD charger because I will only use the car as an everyday driver. I'll enjoy the instant torque, and it will have less parasitic loss during normal driving. It should run between 8 to 10 lbs of boost and be around 600 whp hopefully.
Old Dec 3, 2018 | 08:35 PM
C7&7's Avatar
C7&7
Awesome! Keep us posted.
Old Dec 4, 2018 | 08:36 AM
BooSSted's Avatar
BooSSted
Nice, good luck!! Post the numbers and install pics.
Old Dec 4, 2018 | 02:21 PM
Corvette4ever's Avatar
Corvette4ever
Good choice. What's the exact pulley size you're going with? 3" does not seem ideal for a stock engine as it will give you about 13 psi
Old Dec 5, 2018 | 03:46 PM
samwint77's Avatar
samwint77
I was told the 3" will give me 8 to 10 psi. Do you know someone that had the 3"producing 13 psi? If it gets that high we'll get a bigger pulley. It still comes with the stock pulley. I'll give up HP to protect the motor. I believe due to the headers and x pipe being catless, it will drop the PSI a bit.
Old Dec 5, 2018 | 03:48 PM
samwint77's Avatar
samwint77
Will do, hopefully all parts will be in by next week and we can get started.
Old Dec 5, 2018 | 04:56 PM
Habeas Corpus's Avatar
Habeas Corpus
wow next week would be awesome. I was told my order is 4-5 weeks out? I guess these are not ready off the shelf items
Old Dec 5, 2018 | 11:49 PM
63VetteConv's Avatar
63VetteConv
_______subscribed!
Old Dec 6, 2018 | 08:02 AM
Corvette4ever
My heartbeat kit came with a 95mm (3.75") pulley. This gave about 7.5 psi with the stock engine/exhaust.
3" pulley is 76mm, check this post for reference https://www.corvetteforum.com/forums...post1594843195
Old Dec 10, 2018 | 12:44 PM
samwint77's Avatar
samwint77
Thanks for the info, I'll be sure to discuss this with my tuner. I did call Magnuson and told me due to the headers and x pipe I couldn't use the stock pulley, but I didn't ask why. I'll be sure to post what comes out of this so others will know if they decided to go the maggy route.
Old Dec 14, 2018 | 12:46 PM
samwint77's Avatar
samwint77
A quick update, Got the headers and x pipe in monday. Still waiting for the maggy.
Old Dec 14, 2018 | 04:13 PM
Habeas Corpus
My 2300 was just delivered. I have a 2015 ZO6 so I ordered the upgrade supercharger kit with 80mm / 3.15” pulley. Should be close to 12 psi. I’ll be installing the 95mm ZR1 TB.
Old Dec 15, 2018 | 01:35 PM
Z06Brucey's Avatar
Z06Brucey
Sub'd
Old Dec 21, 2018 | 01:00 AM
spinkick's Avatar
spinkick
Watching this thread. I have the same car and now thinking about the maggy..
Old Dec 21, 2018 | 01:29 PM
MCK_Z06's Avatar
MCK_Z06
I just did a 2300 with port injection... It will be going on the dyno in a few hours.
I'll post up and let everyone know what it did later tonight or tomorrow.
Old Dec 21, 2018 | 01:34 PM
spinkick's Avatar
spinkick
z06? Sounds like you are going for some major power. 750-800whp?
Old Dec 21, 2018 | 01:53 PM
MCK_Z06's Avatar
MCK_Z06
Yes, its a LT4/Z06.
I was a little over 750whp on E85 (E65 at the time of the tune/dyno) before the swap. (FBO/H/C/I & ported stock blower/snout, 103mm TB, port injection on stock blower, full flex-fuel setup, LG full cooling setup, etc.)
So this round is basically a blower swap only using the kit upper pulley that comes with the Magnuson and retaining the mods that were already in place.
I do have an 18% lower already on that will stay.
It will be interesting to see what it makes.
My goal was to build something close to 1000HP at the crank or a little less without having to use meth, with a full flex-fuel setup that will be somewhat reliable.
Im close, so hopefully this gets me a little closer.
To Welp, pulled the trigger
Old Dec 21, 2018 | 02:06 PM
spinkick's Avatar
spinkick
Sounds great. How do you like the LG cooling? Was it a bitch to install. Was considering it when I do a Maggie heartbeat on my grand sport.
Old Dec 21, 2018 | 02:30 PM
MCK_Z06's Avatar
MCK_Z06
The cooling kit works very well.
I actually had to dial the fan back a bit because on cooler days it took a bit to warm the engine and oil up.
Otherwise the temps are inline with my NA Z06 (minus the higher IAT's from the PD blower.)
170-180ect, 175-185eot, IAT's coming out of the blower are around 90-100deg. unless its 100+deg. and I'm beating on the car then I have seen it hit 150deg.
I actually live close to LG's HQ so I just had them install it, so it was easy.. lol!
Old Dec 25, 2018 | 09:31 PM
samwint77's Avatar
samwint77
Got the confirmation last week. My laggy should be shipped on the 28, and car will go in the first week of January. Getting a little excited....
