C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Alky Kit
Old Nov 27, 2022 | 08:36 PM
GreenVette9's Avatar
GreenVette9
Default Alky Kit
Who has the best alky kit that uses the 2-1/8 gauge to control it. I have an extra hole not being used on my a-pillar pod.
My car is rear mount turbo making 550 to the wheels on 93 with pretty much no timing and 7psi.
Would like to make around 700 to the wheels.
Old Nov 28, 2022 | 09:35 AM
C7&7's Avatar
C7&7
Not sure of any that use a round gauge to control it. It's not really something you need to "control" at all. It'll be set during tuning and not really after that. I would just go with the Alky kit and put the controller behind the radio and add some other gauge to your pillar .
Old Nov 28, 2022 | 06:24 PM
GreenVette9
Did some looking around today and Snow has one with the gauge. Has anyone here ran there's before? Any problems with it.
Old Nov 29, 2022 | 06:59 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
I'm a big fan of AlkyControl and have been buying from Julio in Florida for decades now. He can get you setup for sure.
Old Nov 29, 2022 | 08:07 PM
GreenVette9
What alky control kit would you recommend for 700whp? Would need to run straight alcohol for added fueling and octane.
Would it make any difference if the alcohol was injected at the rear of the car and go thru the intercooler.
Will there kit use a seperate tank or can you use the windshield washer tank. And how does the plastic tank hold up to alcoho?
Old Nov 30, 2022 | 11:05 AM
Usually M15 single nozzle kit for that power goal. I prefer tuning with straight meth no mix. You would put the nozzle pre-throttle body and use a IAT breakout harness from DSX Tuning. Using the factory washer tank works great and the meth doesn't bother the plastic tank. I just tell guys to replace the meth pump every winter like it's a maintenance item and you won't have any issues.
Old Dec 1, 2022 | 09:05 PM
GreenVette9
Thanks Josh, Talked to my tuner and he prefers the map kit over maf kit.
To Alky Kit
