ZO6 Lite?
Waaaay too much has happened in the last 18 months to lock into anything otherwise. Including what quotes have been cited, or words said by Fritz, or Bob, or Tadge.
And that is both in a negative, or positive sense.
Look at what happened with the Z28? Alive (yea!), then killed (aww..), now back again with an S/C LSx engine (yea!).
Is anyone really going to be shocked if a Z28 is delayed out past MY 2011 or even shelved due to economic reasons?
Times are just too dynamic / unsettled right now.
I would hope we never see a V6 in a C7, but if GM feels that's what they would need to do to sell enough corvettes for the business model to work, so be it... as long as there is a 400+ hp V8 available as well.
Well if that doesn't show history I don't know what does.
Next time I'm going to keep my opinion about this to myself lol
+1000000000000
I honestly wouldn't care if they downsized the motor and dropped off some hp if a lighter corvette came out that equaled overall performance. They will have trouble selling vettes if they are slower then previous generations. They will have trouble selling them with the way things are going period.
I like smaller nimble cars with lots of hp/torque. The C5Z works for me
GM has a LOT of new technologies they can use. A 5.3L V8 would be perfectly OK if they use the right technology in the right way.
Firstly, they should be looking at some of the major accomplishments that other manufacturers had and try to integrate those technologies. Ford built a 2.3L engine that was made mostly out of plastic and made over 300HP. The entire motor weighed around 150Lbs wet! (Check it out here) This was in the 80s! Nissan builds a motor that doesn't require throttle bodies. The intake and throttle are managed by a system called "Variable Valve Event Lift" which is just a solenoid that adds/subtracts lift from the intake valves dynamically. Ferrari removed the use of cams all-together in their race cars by using actuators and switching to a 54V system. The only thing the engine powers besides the wheels is the alternator. Thus reducing power consumption, parasitic loss, and increasing the fuel economy.
Secondly, GM already has the technology for variable timing and variable displacement. They need to combine these technologies into one super efficient engine/electronics package:
5.3L V8
Variable Timing
Variable Displacement
Variable Lift/Duration
Plastic/Light-weight Block Components
Electronic Power Steering Assist (I still don't like steer by wire)
Electronic Water Pump
Carbon Fiber body parts
Carbon Fiber shafts and driveline parts
Carbon Fiber/Aluminum Alloy Frames
Etc....
They can do it, and it's going to cost a lot of money for development and tooling, but it's not to say it's impossible. This is something they should have been doing years ago to start with.
I'm not even sure if the chassis will truly be all new vs. tweaked/revised from the C6. That's basically what they did with the C5 and C6, same with the C2 and C3.
Biography
60 y/o divorced male
Jacksonville, Fl
Interests
building and showing street rods and Corvettes
Occupation
retired
Tow Rig Specs
2004 Dodge 3500 dually diesel quad cab. 48RE 410 limited slip/ All stock
cable internet providers Utah Website Design
There are multiple small displacement vehicles in other car's line ups that produce amazing performance. Look at the Cobalt SS. It went around "the Ring" in 8 minutes and some change. And that's a grocery getter. The little bastards go 12's with a tune!
Look at the performance of the LC2 in the Grand National or the 2JZ of the Supra. Even the POS R35's V6 is impressive.
An all aluminum, forged, twin scroll TC'd V6 in a lightweight Vette would be amazing.
If GM was smart they'd design a V8 like the RST-V8. It's a 2.4L V8 that makes 500HP and revs to 10K! The motor fully dressed weighs 90Kg.
Why go to a TT-6 if you get nothing from it. I am still looking for that high performance TT6 that meets the LS3, LS7 in terms of power, milage and emmissions. Also the driving dynamics of a turbo car are different than a naturally aspirated or supercharged car.
On the RST-V8 the torque is crap. the gear ratios would have to be monsterous. What would the mileage and emmissions be like? Peak HP is not everything. A low torque motor works in a very low weight car like an Elise. However, even the Elise doesn't get good milage with a 1.8 liter motor, even with a 2000 pound weight.
