Interesting Information
Ed W is so secretive about the body style that practically no one has seen it. Obviously none of this is really new, but it does confirm what most of us have heard. My opinion is that all of the pictures seen on this forum are, in reality, far from what the C7 will look like, including that POS from Jolopnik.
How True
Ronnie, I hope your 100% right, but I have a nagging feeling that the Jalopnik drawing got it somewhat right.
http://www.corvetteblogger.com/2011/...anual-gearbox/
I think that would contribute to faster acceleration times, since 4th gear can be a shorter ratio, instead of just the current 1 - 3.
Now if they were going to a smaller engine with a peakier power band then more gears might be necessary..
Not saying Chevy won't add a 7th gear. Just saying with the current engine, or any big cube wide power band engine, it is not really necessary.
As for Mr. W's hiding the Vett, go back and listen to the words he used introducing the Transformer/Stingray concept. I'll give you a starter clue: cockpit, . . . Also the same words were used describing the Koren small car. I'm fairly confident that he will use the same words when he describes the C7. But the execution of those words is where either God is or the Devil is- i.e. - in the details!!!
I really think the engineers and the stylists have two different tasks. The engineers have a lot of technologies on the shelf that can be applied. The stylists have a different task and a diffierent kind of pressure!!! Not only has the exterior and interior to be "on", but the seats better be the best thing sence sliced cheese individually wrapped.
I will try my best to explain this...
A C6 Z51 with a manual tranny accerlerates faster than a base C6 with a manual because the Z51 package, 1st 2nd and 3rd gears have a shorter ratio.
I dont see how you think more gears would be redundant?!? I have a Z51 and my car jumps in 1st and 2nd, but when it gets to 3rd it loses a little pull unlike 1st & 2nd, because its a taller gear. Giving 3rd and 4th a shorter ratio would help acceleration not hurt it.
...exactly!!!
If they do this, the DCT will easily outsell the manual and Corvette sales will florish. However, if they do not do this, they will continue to loose a ton of business to Porsche, BMW, Nissan, Audi & Mercedes, all of which now offer DCT. This is a fact.
Z51 M6 - 3:42 w 2.97 1st gear =10.15 2.97, 2.08, 1.43, 1.00, 0.71, 0.65 2008 and up.
Stock M6 - 3:82 w 2:66 Ist gear = 10:15 same as above.
Stock M6 - 4.10 w 2.66 1st = 10.906
Remember 4th is direct and the other ratios are either under or over drive. You use 4th on dynos and aero tests.
Better to change final drive than change ratios if you want a faster 1/4. Stock ratios are better than Z51 in all counts.
I would like to see 7 ratios with RPM drops <4000 @ each shift. 7th is good for gas mileage on the highway.
These trannies are far different from Hollinger sequential paddle shift ones used in the C6R and some Pratt and Miller street cars.
You could go the Ferrari way but with Corvette torque, look to replace clutches often for spirited street racing. Ferraris owners have to replace their clutches every Wednesday to get ready for the weekend.
I would like to see a comparison of 1/4 mile times for manual cars, some with z51 and some without to test this theory.
But having thought about this, I still contend it is not necessary. It is a sports car, unless the wheels are perfectly straight, with the amount of torque available over a wide rpm range, you can break loose the tires even without the lower gear ratios, so lowering them so the tires will break loose easier will not improve your ability to corner.
And if we are arguing it will make it a faster car on the track, straight or curved, why are we talking about manuals? Automatics will be faster, that is not the point.
