Could this be it..
Old Jan 21, 2012 | 11:46 PM
  #141
XZR1's Avatar
XZR1
And Jalopnik C7 outline over Spy photo
Seems to be a bit differnt at the front, not sure if the camera angle could explain this.
Old Jan 22, 2012 | 12:54 AM
  #142
Qwik01's Avatar
Qwik01
I think the angles are bit different on those.
Old Jan 22, 2012 | 01:34 AM
  #143
XZR1's Avatar
XZR1
Yes the the front it very pointy so probably the nose is not shown properly in this image due to the camera angle.
Old Jan 22, 2012 | 01:41 AM
  #144
LS1LT1's Avatar
LS1LT1
Originally Posted by XZR1
Jalopnik C7 outline over C6 ZR1
I have aligned the wheel base
Hmm, I sure hope they're not making it bigger/longer again (like from C2 to C3 and even a slight increase from C4 to C5), I prefer my Corvettes smaller.
Old Jan 22, 2012 | 02:11 AM
  #145
Nitrous Oxide's Avatar
Nitrous Oxide
Most experts claim that the C7 will have both a longer wheelbase and lower height.
Old Jan 22, 2012 | 02:40 AM
  #146
2KZ28CAM's Avatar
2KZ28CAM
Default I'm back
They are competing with the prancing horse. Of course the C7 will look similar to one. Didn't I say this quite some time ago? I forget. I've slept since then.
Old Jan 22, 2012 | 02:51 AM
  #147
Nitrous Oxide
They're competing with them for the podium at races. But for the wallets, are you sure? If not, why would the comparing look matter?
Old Jan 22, 2012 | 03:45 AM
  #148
LS1LT1's Avatar
LS1LT1
That I can deal with, just as long as the increase in wheelbase does NOT also include an increase in overall length.
Old Jan 22, 2012 | 04:31 AM
  #149
Nitrous Oxide
I don't know about overall length. I would think it's also shorter in that dimension since it is already known to be narrower. And because... European market.
Old Jan 22, 2012 | 10:00 AM
  #150
kp1a's Avatar
kp1a
The original test mule pictures that came out with the C6 body certainly appeared to have a longer wheelbase than the C6. Now, the spy shots of what may be the C7 (as well as the Jalopnic pics) seem to have longer overhangs as well, especially the rear. From looking at this I think we will be seeing a longer car, not shorter. Somewhat disappointing.
Old Jan 22, 2012 | 10:15 AM
  #151
Nitrous Oxide
Could be. However a lower car can produce the illusion of longer or wider proportions. I don't remember exactly which car surprised me in being smaller than my Vette because it was flatter. I think it was the Murcielago or the Diablo.
Old Jan 22, 2012 | 10:24 AM
  #152
kp1a's Avatar
kp1a
True. The fact that none of the angles and distances that are being compared are all different makes it very difficult to judge as well.
Old Jan 22, 2012 | 11:53 AM
  #153
2KZ28CAM's Avatar
2KZ28CAM
I was just referring to some key design elements. Hadn't considered the points you refer to.
Old Jan 22, 2012 | 12:03 PM
  #154
LS1LT1's Avatar
LS1LT1
Old Jan 22, 2012 | 12:16 PM
  #155
C6-Stingray's Avatar
C6-Stingray
The C6 had the exact length of a 2005 porsche 911. Now the New 2013 911's Length increased by 2 inches, that might be as well the case with the C7.
Old Jan 22, 2012 | 02:57 PM
  #156
elegant's Avatar
elegant
GM acknowledged that when they camoe'd the C5 alpha and beta cars, that they grew several inches, sometimes in width, sometimes in length, sometimes both.
So, let's not assume anything about the C7's size based on the camouflaged one undergoing winter testing.
Old Jan 22, 2012 | 08:29 PM
  #157
Motor Fast's Avatar
Motor Fast
If it looks close to the drawing then I am liking the C7. It definitely looks better than the C6, and I have a C6.
To Could this be it..
Old Jan 22, 2012 | 09:58 PM
  #158
XZR1's Avatar
XZR1
To check the photo perspective issue I took some photos of my car from different angles, one from opposite the front of the car one from opposite the rear and one opposite the middle. I used maximum zoom so I could take the photo from far away as possible to minimise the perspective error.
Here is the Jalopnik outline over a composite of the three photos showing that the length is near enough to the same once the photo is fully side on.
This doesn't necessarily mean that the C7 will be the same length, it may just mean that the renderings Jalopnik did assumed the length was the same.
Also it demonstrates how the photo angle makes a big difference so I think the overlay I did over the spy photo probably has significant error due to the angle of the photo. (also lens length plays a part)
Old Jan 22, 2012 | 10:04 PM
  #159
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
It looks like it sits higher off the ground. And the lights and front design of the hood, lights, and grille somewhat resembles an aston martin.
I am so disappointed that it is not going to look like the one from the transformer movies. These renderings don't make me want to buy a new one like I was hoping for and was expecting too for the original concept.
Old Jan 22, 2012 | 10:07 PM
  #160
Mayonayze's Avatar
Mayonayze
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
meh ... if they ditch the "cormaro" tail-lights, i'll probably grow wood for it.
but like someone else said, i am more interested in final performance numbers. if the price point holds (or decreases!) and the base cars are reliably laying sub 4 second 0-60 with meat-shanks of torque all across the range, while providing a MORE connected and natural road feel, then i'll be in one as soon as it hits the lots.
and i hope they dont launch the Z06 or ZR1 along with the base coupe. I want at least one year without model envy
