several serious reasons the C7 is inadequate
Old 01-13-2013, 09:46 PM
  #81
JDMvette7
JDMvette7's Avatar
2018 C7 of Year Finalist
Originally Posted by acannell
I picked the 05 Z06 because, according to the C7 fans, its definitely faster than the current C7, so it makes the point even more solid that the C7 doesnt do the job a brand new version of the vette should, which is at least be faster than the lower priced mustang on a friggin ROAD COURSE.
This is the entry level C7. Case in point: A stock C7 is faster than a stock C6.
JDMvette7 is offline
Old 01-13-2013, 09:49 PM
  #82
bob53
bob53's Avatar
I think the OP has unrealistic expectations and apparently thinks GM can defy physics and economics.
1. Weight: First we do not know the final weight. GM has not released that, they have stated that they saved ~ 120-130 lbs in Al frame and composite use in body panels. I too wish the car was sub 3000 lbs but I suspect for the target price, that was not possible. I am amazed that the base car is coming with a CF hood and roof and can be done for the proposed MSRP. That's amazing! It also suggests that the Z06/ZR1 replacements are likely to have a lot more CF bodywork.
2. Power. With the advent of DI for the same displacement, you can tune for more power or economy. They clearly split the difference here. I think the devil is in the details. If they have a torque curve of the Z06 in a car that is lighter than a Z06, that should be a fun car to drive. Keep in mind this is the BASE car. They probably left a little on the table for a mid-cycle bump in power. Also, as no doubt they have already planned if not built the successor to the Z06/ZR1, they probably wanted to keep a significant HP delta between this car.
3. Power relative to competition - Frankly the use of HP numbers should be banned. What matters in power:weight and we know the corvette spanks the mustang and nearly all other competitors in that fight.
4. Acceleration - mid to low 3's? Given the FE/RWD configuration of this car, low 3's on street tires is going to be difficult no matter the HP. The super C7 vette, whatever they call it, will have the same problem. They might be able to hit 3.2 or 3.1 if we see a F1 style transmission in the future. With a proper manual - it's not likely due to the limitations of physics.
5. There are loads of styling cues that link this with the C2 and C3 - the entire front of the care, rear hatch, etc.
bob53 is offline
Old 01-13-2013, 09:58 PM
  #83
BlueOx
BlueOx's Avatar
Originally Posted by FiberglassFan
Performance numbers are one thing....that awful Camaro rear end is quite another...The new Vette is a reason for better designers to get busy and create some attractive body panels..could actually help the aftermarket body panel busienss being so ugly,,,, expecially the rear!
For what it is, I'm not as against the front of it as I thought I would be....but it does seem to have a total lack of design integration as a whole theme...Arrdvark and Camels come to mind, certainly not Pinninfarina!
I'm keeping my C5.....and in a few years I'm sure its going to cost a boatload of mony to keep going...but if this is the alternative to go newer, NO THANKS, I'll keep my oldster running....
You mean you will be keeping that Pontiac Corvette?? I'm shocked!
BlueOx is offline
Old 01-13-2013, 10:01 PM
  #84
acannell
acannell's Avatar
1. i would have been happier if the car weighed 99 lbs more but had 100 more hp..the trade off in the other direction seems to yield less and cost more.
2. with all due respect, what you say is just a list of excuses.look at it this way: shouldnt variable valve timing, direct injection, and reworked combustion chambers add up to more than 14 horsepower? its their mistake if they are saving up EVERYTHING for the mid model bump. i think they should make a splash now..if their big plan is to attract young buyers and change the equation, shouldnt they be way beyond the M3 or hell the AMG C63?
3. the corvette does not spank the mustang Gt500 in power to weight. mustang = 5.28 hp/lb, C7 6.8 hp/lb..
4. again, the GT500 hits 0-60 in 3.0 with a manual setup so I think Corvette should be able to do that
5.subjective..i agree with you mostly
I think we should have gotten traction and more power instead of a mild drop in weight...this C7 doesnt really have any "new" ideas or technology..its just the "latest" stuff...or really just "recent" stuff...
is it too much to ask GM to figure out a way to give us near AWD traction without the cost of an actual AWD setup? whatever happened to innovation? only realistic in hindsight, is it?
acannell is offline
Old 01-13-2013, 10:02 PM
  #85
sanchez
sanchez's Avatar
By stupid do you mean the GT500 will be 2 seconds faster than an 05 C6 Z06 at Laguna Seca?
Power matters...this is a CORVETTE forum right? Are we seriously saying that less power is okay? WTF has happened here??
http://fastestlaps.com/tracks/laguna_seca.html
Something is off with that link.
There was no '05 Z06.
Don't let that stop your butt hurt though.
sanchez is offline
  #86
phlounda
phlounda's Avatar
Im waving to C7's. I wave to any corvette, including C4's. You dont? Shame on you A vettes still a vette.
Of course I wave to C4's I own one, and love it.
phlounda is offline
Old 01-13-2013, 10:05 PM
  #87
C3DeedlyDee
C3DeedlyDee's Avatar
Except you took the '05 Z06 and not the CURRENT C6 Z06. There is a difference, you know? Now the Z06 has revised suspension, improved aerodynamics, and much better tires than the crap Eagle F1 tires they first had. With time comes design progress. It's a crazy concept, I know by your reasoning, perhaps I should compare new Corvette times to old GT500 times.
For ***** and giggles, I looked up ALL the laptimes for the '13 GT500 on the site you linked:
Laguna Seca: Slower than any of the latest (2011 listed) Z06 runs. No Grandsport times listed
GingerMan Raceway: GT500 not only has a slower laptime than a base C6, it's the slowest laptime of any car listed. Slower than a Porsche Boxster. Awsome...
Grattan Raceway: Faster than a Z51 C6 by less than a second. Pummeled by both ZR1 and Z06. No Grandsport times listed.
Sachsenring: No vette times to lose to, but it has a slower time than the ZL1 on here.
Virginia International Raceway: Slower than the Grandsport Corvette by over 2 seconds!
Again, this car is supposed to be faster than a C6 Grandsport in base form, and lo and behold, look how the Shelby's laptimes compare to the latest of Chevy's offerings. Oh. My. God.
C3DeedlyDee is offline
  #88
briannutter1
briannutter1's Avatar
I think we'd all have a good laugh if the OP posted a picture of himself.
briannutter1 is offline
Old 01-13-2013, 10:07 PM
  #89
Thud
Thud's Avatar
5- this car has no links to the stingray..calling it that is ridiculous...it doesnt have the curves and it doesnt have the mystery
Define "mystery?" Stingray was just as much of a marketing thing for the C3 as it is now.
Thud is offline
  #90
rockstar
rockstar's Avatar
To call this Cormaro a Stingray is blasphemous
rockstar is offline
Old 01-13-2013, 10:10 PM
  #91
acannell
acannell's Avatar
and why would that be?
acannell is offline
Old 01-13-2013, 10:12 PM
  #92
su8pack1
su8pack1's Avatar
su8pack1 is offline
  #93
Mdm23
Mdm23's Avatar
Stop starting these theoretical threads people. The HP numbers are not necessarily final. No tests have been released. A lot of people said jalopnik was crazy and this car basically looks 100% like their original rendering. The 13 gt500 was estimated at 600 HP, then, 650, and finally ended up with 662. Give it time.
Mdm23 is offline
Old 01-13-2013, 10:14 PM
  #94
supermetroid
supermetroid's Avatar
Don't worry pal, all you need is E85 fuel and you will smoke the C6 ZO6 while getting better gas mileage and making it look centuries out of date.
Do you feel better now?
supermetroid is offline
Old 01-13-2013, 10:15 PM
  #95
AGFNTB
AGFNTB's Avatar
1- the jump from C5 to C6 was a 50 hp increase!! the C6 to C7 is 14? isnt that a K&N filter on the LS3? they say the torque is like the LS7 at low rpms..will have to see how relevant that is.
2- the base C6 was as fast as the previous Z06!! The C7 will weigh more than the C6 Z06 and have 50 hp less power....is that supposed to be exciting? Im not saying the base C7 should be a C6 ZR1..but its been 8 years!!! The C7 should be breaking the C6's records in a big way!
3- when the C6 came out with 400hp, it had *100HP* more than the brand new mustang...the C7 with 450HP isnt doing anything special..thats just average now for sports cars
4- this car needs to be in the solid mid 11's with a mid to low 3 second 0-60 to be exciting, especially at $59 grand.
Heres what the C7 SHOULD have been:
200 lbs lighter..figure it out GM
better seats and a somewhat nicer interior
535 hp
11.4 quarter mile, 3.4s 0-60
LED headlights (not LED DRL's)
NOT a camaro rear end
$55000 base model with those specs
"Serious reasons" :c razy:
AGFNTB is offline
Old 01-13-2013, 10:16 PM
  #96
acannell
acannell's Avatar
It also shows that the GT500 is only 2 seconds slower than a 2010 911 GT3 RS, or faster than a GTR, so obviously there is some noise in the data.
The point is that the GT500 is in the same league as the corvettes on a road racing course, and costs $5k less than the C7. It is in no way just faster in a straight line.
acannell is offline
Old 01-13-2013, 10:17 PM
  #97
acannell
acannell's Avatar
Thats an odd idea for a forum with the word "speculation" in the title.
I agree with you about the numbers though, no way did all those engine changes add up to only 14hp, unless its all for MPG.
acannell is offline
To several serious reasons the C7 is inadequate
Old 01-13-2013, 10:20 PM
  #98
c7rvette
c7rvette's Avatar
Originally Posted by Crossofiron
If you just wanted to be a party pooper you did it.
You do not have any real evidence about the performance of this car so you fail.
The C7 to me is like a blind date that you cant wait to be over...I guess I will be optimistically be waiting for the C8. Now if she was a monster in the sack I would give her another chance....only until somethin nicer came along...GM did not out do themselves with this car....I hope they outsell the C5's or the C6's, but I would bet against it big time!!! GM you could of done a better job. I will say for the money, I would spend another 20 grand and buy the zr-1. I wouldn't even consider the C7. Again, I hope I am proved wrong, cause I am a vette lover......let the jury decide!!!
c7rvette is offline
Old 01-13-2013, 10:22 PM
  #99
sam90lx
sam90lx's Avatar
Originally Posted by manfromuncle
Love corvettes. Love this one. Will wait for the Z06 or Z07, whatever they decide to call it and buy one then. For now, my C6 GS will have to do.
Ditto.
sam90lx is offline
Old 01-13-2013, 10:23 PM
  #100
oicw
oicw's Avatar
acannell, I'm not going to jump on the bandwagon and start attacking you, but want to point out why I think your expectations are unrealistic:
You mentioned low to mid 3s 0-60. Problem is not power, but traction and transmission. For that to happen, especially on the street, you have to be on drag radials day in day out. My Z06 would be lucky to get low 4s on most street surfaces, because not once have I NOT spun through 1st, and I have Cup tires...
Mid 11's? Again, highly unrealistic because the Vette lacks 1) AWD, and 2) dual clutch transmission. Couple those 2 together you have yourself a $100k car. Hotshoe drivers may get it into the 11's, but trashing the transmission synchros in short order.
HP - we don' know yet. Yes 450 is a little low, but the drive-ability will be awesome, better than my LS7. Likewise, the street manners of the LS2 was better than LS6.
Also, look at the efficiency of the Vette. Find ONE Japanese or Euro car, 450+ hp, with better mileage. In fact, most 350/370Z get no better mpg than my car, and I spank them pretty bad...
oicw is offline
Quick Reply: several serious reasons the C7 is inadequate
